Question about Kyocera Cameras
Kyocera yashica Tzoom film 35mm camera- I loaded a new battery and the battery icon on the top display panel flashes empty, and camera does not activate. I have tried several batteries without success. Can you help please. I will be in Japan next week for a few weeks, and wonder if there is still a Yashica service centre in Tokyo ?
  • 38 Answers
SOURCE: address of kyocera yashica authorised service centre
why don't you try www.247servicecenterinfo.com, they have listing of all kyocera service centers in india.
Posted on Mar 23, 2009
I want to know the service center address and contact number of yashica in manila, quezon city or makati- philippines.thanks
For all inquiries regarding Yashica film cameras, the closest center to any of those locations is:
line_dot_600.gif KYOCERA Hong Kong Logistics Co., Ltd. 6th Floor of Niche Centre, No.14 **** Tai Road, Kowloon Bay, Kowloon Hong Kong, China TEL: 852-2343-5151
FAX: 852-2343-2472
From their website:
"If you are located in Asia, the Middle-East, or Oceania and have an inquiry related to YASHICA film cameras, please contact KYOCERA Hong Kong Logistics Co., Ltd. in Hong Kong."
please see:
http://global.kyocera.com/prdct/optical/global/#s02
Mar 30, 2011 | Cameras
My cannon eos 500 wont take a picture it just displays empty battery
canon eos500 cannot use LCD screen on auto focus mode - the screen will only display menu setting
Nov 23, 2010 | Canon EOS 500n 35mm Film Camera
I have a Canon Sure Shot 115u II Date 35mm Film Camera. No manual. How do I fix the blinking icons on the LED screen? There are a series of dashes along the top of the screen. They look like a place...
remove the battary and the film,the clean the contcts of the bat and bat comparment, and put the battary then operate camera without film.finding it normally operating for 10-20 clicks,put the film and try
Mar 04, 2010 | Canon Sure Shot 115u II Date 35mm Film...
I don't know how to open it to put new film in?!?!!
Do you mean "Yashica"? If so, pull up on the film rewinder knob on the top-left side of your camera. The film door should pop open.
I still have my old Yashica "Electro 35". Don't use it anymore as I've gone digital, but it still is a pretty cool film camera.
May 02, 2009 | Cameras
Film Loading Error
This also happens to Yashicas often. (though instead of stirpping the film, it will rewind it back into the roll. Something's wrong with either the firmware or the drive system. It'll need to be taken to a camera repair shop, or you'll have to send it back to Canon for warranty service, if it's still within warranty.
Dec 04, 2008 | Canon EOS Rebel GII with 35-80 lens 35mm...
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Camera wont accept any film?
1.The film leader should be placed correctly.
2. the ASA detecting pins in the film champers should be clean.
3. Check for any buttons being in pressed conditions.
4.See whether the frame counter resets when opening the door
5.Then try with a mechanic.
Mar 26, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Kyocera Finecam S5R digital "flash close"
You forgot to open the shooting flash on the top of camera
Nov 24, 2007 | Kyocera Finecam S5R Digital Camera
Battery problems
Check the battery contacts inside the camera. Use a strong light, and if you see corrosion (black or greenish areas) on the contacts, rub them lightly with a pencil eraser until they are shiny.
Apr 05, 2007 | Canon EOS-1V with 28-105 and 100-300 lens...
Cameras Logo
26 people viewed this question
Top Kyocera Cameras Experts
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
