Question about BenQ FP731 17" LCD Monitor
IBM T41 Hi, guys, i'm working on two T41 IBM laptop : problem ...is no power. I checked for Voltage on the power switch , got { 0 volts} some parts of the board has power. I do Electronics and PC repairs, need help with this one. Thanks.
    Genius:
  • 1,847 Answers
Is the power supply fan working?
Posted on Sep 22, 2008
  • Legin Varghese
    Legin Varghese Sep 22, 2008
    There is definitely some issue with the motherboard. the only option is to replace it.
I seem to be locked out of my ibm thinkpad t41 it wont let me switch it off or access ibm
Locked out how? With a password? You can't switch what off? Press and hold the power button until it shuts off or Just unplug it and remove the battery as a last resort. With no power source, it will cut off.
May 30, 2012 | IBM ThinkPad T41 Notebook
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
Recovery cds for ibm thinkpad t41 laptop
Hi there.
Unfortunately you cannot download the recovery CD for free, you can download them but it is going to cost you.
Take a look at this site for all IBM Thinkpad recovery CD's >>>>
http://www.thinkpadrecoverycds.com/
Good luck and thanks for using FixYa!!
May 26, 2009 | IBM ThinkPad T41 Notebook
How do I use blue tooth on my laptop IBM T41?
It depends upon what you mean by "USE".
0. Do you HAVE bluetooth?
- there is a bluetooth light over the keyboard (of course probably not lit)
- there is a bluetooth identifier on the bottom of the laptop
- the FN+5 key brings up a menu of (possibly, wireless) and Bluetooth.
0.1 if NOT then you need to ADD a bluetooth USB adapter
Usage:
1. Use to synchronize a PIM or cell phone or other DATA connection
- This should be fine; you need to solve (0) first (that you HAVE the hardware) then the driver, then have it running
2. Use a bluetooth headset to listen to audio.
- this you can *NOT* do with the default IBM bluetooth stack - I tried, an "audio adapter" for the bluetooth was simply not supplied by IBM. It would require changing to some non-IBM bluetooth stack, and I chose not to do that so never got a bluetooth headset working with my T41.
Apr 04, 2009 | IBM ThinkPad T41 Notebook
Ibm t41 sound not working
Just to try the obvious...
The volume buttons on the laptop underneath the screen work independently to the volume controls in Windows. Have you tried pressing and holding the volume up button and then playing a sound?
Jan 21, 2009 | IBM ThinkPad T41 2373 Notebook
No backlight
with a multimeter verify if you have power in inverter, if not, try to connect the inverter to another power supply for testing.
Jan 06, 2009 | IBM ThinkPad T41 Notebook
Battery not recharging.
Look on the charger itself & it will have the correct output voltage & polarity stamped on the charger. Then get a volt meter to verify if the correct output voltage is present. If the volt meter reads less than what is stamped on the charger, then I would recommend replacing the charger at that point.
Nov 20, 2008 | IBM ThinkPad T41 Notebook
Graphics card damaged can you remove or they built into mother board
Connect an external monitor, press F7 to switch displays. If all is good then the video card is ok.
Oct 18, 2008 | IBM ThinkPad T41 Notebook
IBM Thinkpad doesn't start
Visit Lenova's troubleshooting page at
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4YQJZX
I assume you have verified the battery and AC adapter with another machine or a voltmeter.
If none of the above get it going, you most likely have motherboard issues, possibly a blown fuse.
Or possibly a keyboard Power On switch problem.
Good luck.
Apr 28, 2008 | IBM ThinkPad T41 Notebook
BenQ FP731 17" LCD Monitor Logo
43 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
