Question about Admiral AAV7000A
Admiral clothes washing machine AAV7000AW
When in spining cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
  • 1 more comment
  • calmtouch Sep 19, 2008
    I looked under the washer. The only way the tub is connected is it is setting in a hole at the bottom. I tried to tighten anything under the tub..all was tight.I can move the tub from side to side very easily. I did this while looking underneath. I moved everthing. It does not look like the tub is connected to the washer frame except by the agitator shaft.
    It will spin evenly with no load. As soon as I put something in the tub, the tub moves from side to side.
    I have not manual with the machine.
    More suggestions?
    Thanks.
  • calmtouch Sep 22, 2008
    Dear Huuum,
    Ok, get ready for this. I reloaded all the clothes in the washer several times to even out the load. I took out half the load and moved the load around to make it even. The washer still spun out-of-control. I then took out most of the wet clothes and still the barrel whiped back and forth hitting the sides. So, I emptied it. It spun fine.
    I took the machine sides off and checked the springs, belt, couplings, etc, and all was fine. I then called a repair person.
    Today the repair person came and no matter what I did, the machine spun like it was brand new. I explained what I did and why. He offered me a job. I still felt like an idiot, especially since I have fixed machines before. We just laughed as I hit my head against the laundry room wall. $$ later, I am doing my first wash after the event and it is fine.
    Thank you for your suggestions.
  • icemanjtice Oct 02, 2008
    i have same problem, as you call it , walking machine, can anything be tightened, belt or anything, admiral washing machine
  • 750 Answers
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Posted on Sep 19, 2008
  • Neil Golan
    Neil Golan Sep 20, 2008
    Calm touch,
    You said, The only way the tub is connected is it is setting in a hole at the bottom.
    Inside that whole at the bottom is the coupling that connects to the transmission!
    If the coupling is worn, it has play and will... bang around when weight is applied!
    How old is the washer?
    Once a washer is 7 years or older it is not recommended to put good money into bad!
    But to replace the washer.
    Consumer report just ran an online article about this also!
    Let me know what you do.
    Huuum
    Don't forget to leave a rating!
    Thank You
  • Neil Golan
    Neil Golan Sep 22, 2008
    WOW YOU have an intermittent problem until it goes and you can really know what it was!!!!!!!!!!!!!!!
Our admiral 7005l washer has a build up of black gunk around barrel , any ideas?
Mildew because you are using to much soap. The mildew hangs in the extra suds in the washer and feeds on the skin and food removed from your washing the clothes.
Mar 14, 2015 | Admiral Washing Machines
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
THE MACHINE SHAKES WITHOUT CONTROL
During the spin cycle if your cloths are too heavy on one side you will get this problem, reposition the cloths and it should cure the problem, at least thats what I do when my machine gets to shaking.
Aug 28, 2009 | Maytag MAH8700A Front Load Washer
The admiral washing machine works fine except on the spin cycle it wabbles wildly, like the clothes are loaded on one side. but does it even while washer is empty
At its best this washer is a beast in the spin cycle. The machine must be mounted on a cement floor. It is written in the unpacking instructions. Check all springs, machine must be level. If all checks out replace snubber ring or adjust by centering snubber ring Mounted unde the transmission base.
Jun 22, 2009 | Maytag Admiral AAV7000A
Washer tub bangs when in spin cycle
There is not a repair guide , sounds like a spring may have broke or came loose inside on the frame take the front panel off to check for loose parts.
it may just be an off balanced load as well.
Phil
Apr 15, 2009 | Admiral AAV7000A
Vibrates and moves during spin cycle
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Dec 27, 2008 | Admiral AW22 Top Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Admiral AAV7000A Logo
567 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
