Question about Piper Products Freezers
Commercial reach in freezer
Can anyone tell me the average life of a commercial, 2 door, reach in freezer?
Thanks
  • 750 Answers
Hi scondon15,
I just read this article about the subject you ask about!
How old is the freezer?
Repair or replace?
When to pull the plug on your old refrigerator and or freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 22, 2008
The unit not rich temperature
Hi, This can tell us many things such us : -; Compressor malfunction - Low refrigerant level - Thermostat wrong setting or malfunction - Door ajar - etc.
My suggest go check and fix ( if any problem) with first 3 items above ( these item have potential problem that cause you never reach your intended temperature).
regards,
Dec 16, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
I have a commercial reach in Turbo Air 2 door freezer that is 1 year and 2 months old. The compressor is going out.....Why would it happen?
I've never heard of "Points going out" and I've been doing commercial refrigeration since '85. I can only guess that he is referring to either the potential relay or the current relay. In either case, the part costs about 30 bucks and takes about 30 minutes to install. I'd look for a second opinion for sure.
Aug 27, 2010 | Freezers
Where are the defrost timer and defrost thermostat located on the Delfield commercial reach in freezer, model number F1FR?
depending on the age it might be built into the board if it dont have a board the timer might be close to the compressor
Apr 29, 2010 | Delfield Freezer ColdPro Solid Door...
Where can I order extra shelves and support clips for GST 40GF
Call Rick at Restaurant Parts and More in Ohio. Give him the model and serial numbers and he can match what you need. FYI, most Turbo Air freezers are also Masterbilt. Turbo Air does the private lable thing for Master bilt.
Hope this helps.
Mar 11, 2010 | Turbo Air Freezer Green World by Bottom...
Commercial walk in freezer door damaged needs repair or replace?
I Need two panels replaced on my Walkin Cooler, is there anyone that cacn give me a quote/price for this repair
Nov 14, 2009 | Freezers
A Delfield Mdl 6151-S 2 door stainless freezer into a cooler? Change thermostat? It cost me $25 . Factory service says it's not practical. What is practical?
to do it right, you gotta get technical. Need to know the BTU rating of the evap coil. Then match the compressor/ condenser coil and the expansion device to the same BTU rating. Can prove to be somewhat expensive. Your unit probably has a 3/4 h.p. compressor. This is pretty big for a 2 door unit. Probably too big, but again, gotta get the technical on all that stuff.
Jun 03, 2009 | Randell 47 cu. ft. / 1331 liter Commercial...
True Commercial freezer not cutting out
Tech. can not find freeon leak in line but endicator is regestering freeon leak in side of back panel.
Jun 04, 2008 | True 52 cu. ft. / 1472 liter Commercial...
Freezers Logo
172 people viewed this question
Top Piper Products Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Piper Products Freezer Expert? Answer questions, earn points and help others
