LCD display problem
OSD is ok ,data display is not ok
  • manoj ar
    manoj ar Sep 19, 2008
    IBM ,9493-AW1, HAS A DISPLAY PROBLEM,OSD IS OK BUT DATA DISPLAY IS NOT OK
    Brigadier General:
  • 5,158 Answers
Seems to be a definate electrical issue tho i doubt it is the motherboard. I can't clearly tell from the picture.... is the display cover the whole viewing part of the monitor or not ?
i suspect that monitor is failing... just not certain if it's a board issue or the lcd screen itself.
Some questions do spring to mind... have you jarred the monitor recently... although it usually manifests itself as a colour issue unhook the cord that plugs into your video and inspect the pins. try a replacement to eliminate that if you have a spare.
Very old fashioned test that will confirm some things.... smack the side of it (not to hard) and changes.... and don't hit it alot just enough to see if there are changes.
Robert
Posted on Sep 19, 2008
  • 928 Answers
Have you already tried to do a Degausse? That would be an option on the Display menu.
Would you be able to try another computer and connect it to the monitor? This will help isolate the problem.
    Novelist:
    Champion:
  • 203 Answers
What the the model number of this unit?
  • experttv
    experttv Sep 19, 2008
    Ok, There are 3 things it could be. 1) the computer. 2) the cable between the computer and the monitor. 3) most likely is the main board in the monitor. I have looked and cannot find the replacement part for this but will check another spot tomorrow at the office. Let me know what you find with the computer and the cable! If both of them are good I will get you a part number if there is one available.
    Tim Nolan
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
Hand-me-down N2750W
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Mar 21, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Benq q5t4 monitor. power on "BENQ" display is
i want data for benq q5t4 moniter eprom 24c04 ic my moniter is not working properly
Dec 17, 2010 | BenQ FP51G 15" LCD Monitor
HOW TO ADJUST THE BRIGHTNESS AND SO ON.
Press the OSD button to show the On Screen Display.
Press the UP/DOWN or LEFT/RIGHT buttons to move through the various menu-items.
When you get to the correct item, press OK to select that item.
Then, use UP/DOWN or LEFT/RIGHT buttons to adjust.
Press OK to "accept" the adjustments.
Wait a few seconds, and the OSD will vanish.
Jul 30, 2010 | Acer AL1916W 19" LCD Monitor
Im trying to adjust my philips lcd but menu says "osd main control is locked" how can I unlock it?
In order to resolve the OSD menu locked error:
1. You must reset the on screen display in the menu.
2. Hold down the Menu button for at least 60 seconds.
3. A menu list will appear on your monitor screen.
4. Using the adjust button, press the arrows to enter the menu.
5. Scroll down to the Reset section.
6. On the right side of your screen, you will see an alternating Yes/No choice.
7. When the Yes message flashes, press the Ok button.
8. The menu should be reset and the flashing OSD control message should disappear.
Apr 12, 2010 | Philips 190B6CB/27 19" LCD
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
OSD Brightness on screen constantly
pls change the contorl buttons ( no 4 )
Jan 04, 2009 | Philips 190B6CB/27 19" LCD
No picture & not able to access OSD to reset
Sounds like your OSD is locked. Press and hold the "OK" button for 10 seconds or so and it should unlock.
Oct 30, 2008 | Philips 170S4FG 17" LCD Monitor
Screen menu displays locked & unlocked
possible faulty VGA Controller board.
Dec 03, 2007 | Gateway FPD2275W LCD Monitor
OSD Locked
try to press "ok" button for more than ten seconds
Sep 04, 2007 | Philips 190B6CB/27 19" LCD
Computers & Internet Logo
364 people viewed this question
David Payne
David Payne
