Question about Acer Aspire L310 (ASL310UD631A) PC Desktop
How open Acer L310 case
My computer is locking up. I suspect overheating as I don't think I hear the fan running. Exactly how do I open up the computer case? Anybody know where I can buy a replacement fan(s). I understand Acer doesn't sell parts.
On newer computers... especially desktops, the cooling fans are using a new brand of a.b.e.c. bearings.the bearings make it run faster and super silent! OH!, and one question before you VOID YOUR WARRANTY...... do you sit the case on the floor or back to the wall?
Posted on Sep 19, 2008
Running an Acer Aspire ax5900. The video card fan vibrates loudly for the first 10 minutes of startup. I'm told I need a new video card. Area is clean and dust free. Where is the best place to find a...
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
I have an acer aspire ax5900. The video card fan vibrates loudly for the first 10 minutes after start up. I am told I need a new video card. Is this correct and where is the best place to get one?
Normal Operation
Troubleshooting
Solution
Just want to now what is the biggest duo 2 cpu can you put in the acer aspire l310 desktop
This is the standard equipment for your model.
Problem is, your system is already maxed out for heat.
If you add a faster CPU, you will most likely suffer from overheating, but yes you can add up to a 3 gig+ duo with no problem fitting it in the socket. Expect your power supply fan to run constantly though.
Processor: 1.86GHz Core 2 Duo E6300
Memory: 1GB DDR2
Storage: 320GB hard drive
Optical Drives: Double-layer DVD±RW
Monitor: None
Graphics: Integrated Intel GMA 3000
Operating System: Windows Vista Home Premium
Aug 30, 2010 | Acer Aspire L310 (ASL310UD631A) PC...
Acer
Hi
I'm not sure, please open the computer case and see if there is a free pci slot.
Note that opening the computer might void warranty.
Also, you would do fine with a USB Wifi adapter. cost around the same if not cheaper.
Thanks and good luck,
let me know if you need anything else.
Ekse
Apr 27, 2009 | Acer Aspire L310 Desktop
Want to add graphics card. how do you open computer?
You can't install another video card in a Acer Aspire L310. It does not have an expansion port for it.
Jan 23, 2009 | Acer Aspire L310 (ASL310UD631A) PC...
Difficulty locating memory chips in my Acer Aspire L310
visit youtube web,, there so many video how to install ram or laptop desktop hardware installation
Jan 08, 2009 | Acer Aspire L310 (ASL310UD631A) PC...
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
System will not boot
Any output on the screen at all? If no, probably the processor.
Do you hear fans running in the back, where the power plug comes out? If no, probably the power supply.
It's really hard to tell on thing like this. It could be the power supply, motherboard, processor, or any combination of those things.
May 16, 2008 | Acer Aspire L310 (ASL310UD631A) PC...
Overheat
Sure it Will,
If you keep running for 24 hours, how Would you feel ??
If you need to run your computer for long periods, keep by a well ventilated area ( slightly open Window ) for extra Cooling.
If you Have legs on the underside, open them up, so that the laptop is off the Desktop. ( air circulation Underneath )
Place on a solid surface ( wooden top et,c )
Make sure nothing can interefere With Outlet ports. ( Fan Blower )
But In general Not recommended.
Thankyou For Using Fixya :)
Mike :@ Compurepair.
Feb 28, 2008 | Acer Aspire 5315 Notebook
Acer Aspire  L310 (ASL310UD631A) PC Desktop Logo
286 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
