Question about Lexmark Office Equipment & Supplies
Lexmark Z1300 Cannot start Print Spooler. Tried computer management services and applications. NG Also typed 'cmd' in run window, hit ok, black box came up, typed in 'net start spooler' did not work. What can I do next?
Cleaned Registry...Problem solved.
Thank you,
Ed Seewald
Posted on Sep 22, 2008
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
Spooler not runing
1. Click Start ---> Run 2. Type Services.msc 3. on the list look for Print Spooler Double Click
4. Set the dropdown to automatic... Click on start apply ... and then click on OK
Thanks for Choosing Fixya
Jul 18, 2011 | Office Equipment & Supplies
I cant get a print job to delete from the queue and its holding up all the other jobs
To delete print jobs stuck in the print queue on Windows:
  1. Click Start ? click Control Panel ? click Printers and Faxes.
  2. Right-click on the Lexmark print object and select Cancel All Documents.
  3. If that doesn't clear the queue, restart your computer.
If print job(s) still remain in the queue even after doing the steps above:
Stop the Print Spooler service from the Services console
  1. Click Start ? click Run ? type cmd ? click OK.
  2. Type net stop spooler at the command prompt ? hit Enter on the keyboard.
Clear the SPOOL folder
  1. Click Start ? click Run ? type spool ? click OK.
  2. Open PRINTERS folder ? delete all files in the folder.
Start the Print Spooler service from the Services console
  2. Type net start spooler at the command prompt ? hit Enter on the keyboard.
Try to print again after clearing the print queue.
Nov 24, 2010 | Lexmark Z611 InkJet Photo Printer
Ricoh Aficio CL3500N Laser Printer How do I clear the print que from the printer?
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jul 01, 2010 | Ricoh Aficio CL3500N Laser Printer
Print jobs stuck in cue
Click on Run
Alternate method,
Click STart
Click RUN
Type
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jun 25, 2010 | HP LaserJet 8500 Color Printer
Won't print , status que sys it is.
Click on Run
Alternate method,
Click STart
Click RUN
Type
Jun 22, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Printer is nat responding to print comands, a message about spooler subsystem popped up when i restarted the conputer.
Somehow, the print spooler of your computer got disabled. Here's how you enable it. Go to Start Menu > click on Run (for XP)/Search (for Vista or Windows 7)> type services.msc then hit Ok. Services window will pop up. Look for Print Spooler in the items (it's arranged alphabetically). Right click on Print Spooler > click on Properties. Printer Spooler Properties window pops up. In General tab, make sure that Startup type should be Automatic and Service Status shoud be Started. Then go to Log On tab, uncheck Allow service to interact with desktop. Hit Apply and then hit Ok to save the settings. If problem is not resolved, place a comment so I can get back to this. Thanks.
Apr 04, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Spooler service not working?
If its Xp Click on Start > Click on RUn
Type in CMD Click on Ok
Type in the command in there :
SC CONFIG SPOOLER DEPEND= RPCSS (Press enter)
Restart the computer
Again open the CMD type in:
NET STOP SPOOLER (Press Enter)
NET START SPOOLER (Press Enter)
Try to Print
Note : In case of VISTA type CMD in Start Search
Right Click on CMD Select Run as Administrator and follow the rest.
Regards Soumajit
NET STOP SPOOLER
Oct 12, 2009 | Office Equipment & Supplies
Printer Spool
Windows XP: Click on Start click on Run Type in CMD and hit Ok....... Now type in " sc config spooler depend= rpcss " just copy and Paste the same thing.......... Now after typing that hit enter......... It should say ChangeconfigSuccess.......... Now click on Start click on Run Type in Services.msc click ok..... On the new window Find Print Spooler....... Just right click on it and start it will work fine...... Good Luck............
Windows Vista:  Click on Start click Type in CMD it will show you result for it just right click on the CMD and click Run as an Administrator..... Now type in " sc config spooler depend= rpcss " just copy and Paste the same thing.......... Now after typing that hit enter......... It should say ChangeconfigSuccess.......... Now click on Start Type in Services.msc Hit Ok..... On the new window Find Print Spooler....... Just right click on it and start it will work fine...... Good Luck
Jan 28, 2009 | Lexmark Z645 InkJet Photo Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
