Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer the washer will wash but will not spin the water out. It sounds like it wants to begin to spin but then it just stops and makes a ticking sound.
I just had this problem the other day, it is the lid switch that is broken. It is only made of plastic, so if someone closes the lid too hard, it will break. We actually had it removed, and now w don't have any issues. Apparently it is there, so at anytime, if someone lifts the lid, it will not stop the machine from doing what it is doing.
Posted on Sep 19, 2008
My frigidaire LTF6700FSO will not spin
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Water begins to fill then stops followed by ticking sounds, was working for the last 3 years!
Relays on the ECU are failed. You must replace the ECU to solve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
My Stackable washer/dryer is not operating right
Two things:
1) I would first check your water pump, if something gets in it or the water pump bearing is bad, it makes this kind of a sound.
2) If you can spin the washer drum by hand in either direction, the transmission is bad.
Good Luck!
May 03, 2009 | GE Spacemaker Washer and Dryer Electric...
Will not discharge water or go into spin cylcle.
I would have to guess you have a dead spot in the timer. If it stops moving, it would still tick like a clock but the internals of it are not catching to send it into discharge and spin.
Apr 03, 2009 | Washing Machines
Kenmore Elite HE3 fills but won't spin
do you hear any sound while stops??
like ticking sounds?
Jul 15, 2008 | Kenmore Elite 45986 Front Load Washer
Ticking/chirping sound during slow spin
it will more than likely be a bra wire stuck between inner and outer drum it will only sound when clothing is in it due to the weight of clothing and water so it wont be heard with just water init or by pushing it around by hand only thing u can really do is eiether strip it yourself or by getting an engineer in but what i would do is leave it after a while it will dislodge itself and go into the pipe underneath the washer in the pipe that is in the middle of the drum check this when the sound stops love
Aug 22, 2007 | Bosch WFMC 3200 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
