Plug from box is unplugged. Where do we plug it back ?
Posted on Oct 16, 2008
Tv power and OPC lights green and blinking, no sound or picture on screen
Crazy as it sounds, try unplugging from wall, waiting 1 minute and plug back in. If set up to network or cable, try unplugging router, cable box, etc, same thing 1 minute and then plug back in.
Referred to as a "soft reset".
May 25, 2016 | Televison & Video
My power button comes on sometimes and washer works fine. Then sometimes it wont come on. The plug sparks when you plug in if unpluged
IF U HAD SPEAKING ITS ARCHING AND THATS DANGEROUS U NEED TO FIND THE SHORT LOOK AT UR TERMINAL VERY CLOSELY AND LOOK FOR CORRODED OR BROKEN BURNED OUT WIRING, YOU MAY HAVE BLOWN A FUSE SOMEWHERE IN WASHER OR EVEN AT THE BREAKER BOX
Oct 17, 2014 | Whirlpool duet Washing Machines
I was changing the channel and my protron 32 '' t.v. screen turn blue and say no signal
If you are using a cable or sat box for signal unplug it for a while and then plug it back to allow it to reboot.
It is seeing NO signal---either in the set or a box.
Not a bad idea to unplug the set also and then plug back after a short wait to see if it will reboot.
May 26, 2012 | Protron PLTV3250 32 in. LCD Television
No volume from cable
Hello!
First step: reset your cable box by unplugging of the power supply or unplug power cord of the box. If that's an old fashion big gray one or black one with additional power outlet for TV set, there is a power cord goes into. Unplug it, then plug it back in within 1 minute. not the TV itself, but the cable box's power cord. This will reset it. If you have more modern one or small one for non HD TVs, they have external power adapter, which plugs into those boxes.
Pull that plug out for a minute, then plug it back into. That should take care of your sound issue. Known problem.
Good luck,
Let me know if that took care of your issue.
thanks,
Alex.
Dec 11, 2011 | Toshiba 19SLV411U 19 in. LCD TV/DVD Combo
All lights on wont shut down wont respond
Hello, maybe you have to do what i call hard reset, unplug it from the light then look round if you can locate any fuise on the print take it off, then allow it for 1hour and try again later
May 07, 2011 | HP Deskjet F2210 InkJet Printer
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
Humax pvr9300t - power cycling
Unplug box. Unplug aerial. Plug box back in and turn on. Do a factory reset (your recordings will be retained). Turn off box. Plug in aerial. Turn on box, do another factory reset.
That should be it.
If this helps, please write a short testimomial. This helps me to help others.
Regards
Zahc
Feb 08, 2010 | Televison & Video
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Kenmore elite oasis he washer
Lets start by pulling the plug on this machine and while your back there notice where the three screws are holding the console to the machine and remove them until the top comes off noticing how it latches front to back and the screws secure it. Now you will see on the right hand side a grey box, look for a white plug top side left with only two wires sitting by itself and unplug it. Then plug the machine back in and you should still have no power. Next the cable with blue wires connecting the console to the grey box needs to be unplugged. Now we will test that grey box as it supplies your console. The test is as this unplug power, unplug console( blue wires ) then the next step is to plug the white plug with the thick dual black wires in. You should hear it cycle through all the valves, door lock and bump the tub. If this works and after you plug in the console and no power, guess what? Need to replace the console. Ps the plug with the grey sheath by the console blue wires is your door lock:) Write back if you need any help.
Sep 14, 2008 | Kenmore 22422 Top Load Washer
Sound problems on PT 50LC13
try unpluging and plug back in, same on cable box if you have one i have had calls with no sound and found cable box is the problem just unplug for about 30 sec and plug back in
Oct 06, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
