I need to reset my Dell Latitude D820 to when it was new and came out of the box. Dell told me to restart and press ctrl F11 when the Dell logo appeared, that did not work. Tried the same thing with just F11, that also did not work.
You have to press F11 and keep on pressing it but not hold it down. Some menu appears, wouldn't know because i got an HP but with Dells should have a menu for system restore. So just press and keep on tapping it till some bios menu appears that give you more options.
Posted on Sep 19, 2008
How do I factory reset my Dell latitude D510 laptop to default settings
Step 1 Disconnect any connected peripherals from your laptop. This includes USB drives, printers or external mice and keyboards. Connect the computer to only the charger and connect the charger to a wall outlet.
Step 2 Restart the computer if already turned on, or start the computer.
Step 3 Press the "Ctrl" key and "F11" key simultaneously on the keyboard when the Dell logo appears on the screen. The Dell PC Restore by Symantec window appears.
Step 4 Click the "Restore" option. A warning message appears.
Step 5 Click the "Confirm" option. Allow the computer to revert to factory settings. According to Dell, this process normally takes from eight to 10 minutes to complete; a progress bar appears showing the time until completion.
Step 6 Click "Finish" once the process completes. The computer will restart in the same state it was when you first purchased the laptop.
Dec 18, 2016 | Dell Computers & Internet
How to restore setting on my laptop dell latitude d410
Restart the computer and as it is restarting Press F11 and follow the on screen instructions. If this does not work then one, change is necessary which is, as the computer is restarting ,Press F11 and CTRL together and follow the on screen instructions. Some times the key combination is different so try F10 if the above does not work. good luck
May 12, 2011 | Dell Latitude D410 Notebook
How do i restore my dell latitude d410 with out a disc?
Turn the computer on, after you see the "Dell" logo, press and hold Ctrl then press F11, then release them both at the same time. If that dosen't work after the dell logo contunilusly press Ctrl and F11 repeatly at the same time and the dell recovery partition wizard should show up. Source(s): Dell service Repair Expert
Nov 30, 2010 | Computers & Internet
Cannot find the reset for my dell laqtitude laptop
Normally on a Dell Latitude it should be in this sequence,
have your computer shut down, then turn it back on as soon as you see the dell splash screen or Logo press and hold down CTRL+ F11 for at least 4-5 seconds would do, if that does not start the page giving you the option to recover your system to defaults try CTRL+E same procedure as CTRL+F11
If all else fails I suggest Calling dell for a quick info on how to do the factory defaults dell quick restoration .
Dell - 1-877-671-3355
1-800-624-9897
1-800-624-9896
Jun 03, 2010 | Dell Latitude C610 Notebook
Slow dell pleez help
if the comp is off just power up the comp and when you see the dell logo immediately press and hold the CTRL adn tap F11 five times. you will have the option to restore computer.
Mar 09, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
Restoring a dell latitude d420 to factory defaults
This is true that you need to press the right buttons at the right time or else it will not work. Please make sure no changes have been made to the computer and its Hard Drive. Follow the instructions as under:
  1. Make sure the laptop is properly turned off.
  2. Connect the AC adaptor and turn on the laptop
  3. Immediately press the "Ctrl" key and while keeping it pressed start tapping (keep hitting) the "F11" key you should get the Restore screen with various options to restore and repair the computer.
Hope you find this solution helpful.
Thank you for choosing Fixya
Dec 23, 2009 | Dell Latitude D420 Notebook
I need to know how to reset a dell latitude to factory settings?
Press Ctrl + F11 While booting
The moment you see the dell logo Press the Ctrl key and start tapping the F11. If it has the restore image it will take you to the restore page. If there is not restore image it won't work
Sep 16, 2009 | Dell Latitude D531 Notebook
Dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Jan 06, 2009 | Dell Inspiron 1000 Notebook
Need to restore my laptop back to factroy setting
hi,
If you have a dell computer, you can restore your computer back to factory settings using CTRL+F11. You need to restart the computer and when you see the Dell logo. Press CTRL+F11. You will see the message "PC RESTORE"
You may reinstall your operating system using the cd if your system doesn't have the capability to restore settings to factory. You may call you computer manufacturer about it.
Keep me posted.
Thanks.
Oct 26, 2008 | Computers & Internet
Dell Latitude D610 Default Factory Settings
You should be able to contact Dell support and they will send you the CD's for about $25.
May 22, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
