PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Tight laptop lcd hinges
By sonnyliwanag on Sep 19, 2008
my hp pavillion laptop hinges are too tight, already put some penetrating oil in it still to no avail. I disassembled it already and even if used pliers to turn/twist it, its still too tight. pls help help
Same Problem
Apr 13, 2009
-   I was advised to remove the pins in the hinge and use emery cloth to reduce the friction, re assemble with a small dab of machine oil or wd40 and should have lossened up. Be carefull not to reduce the pin too much or will be loose. -   Guest
Solution #1
posted on Aug 27, 2009
Not Rated)
mrwizard8386
Rank: Apprentice
Rating: 0%, 0 votes
on my gateway m series it seems over time they got tighter and tighter until i heard creaking when i opened it. i popped off the 2 plastic covers on either side to reveal the actual metal hinges. i put a few drops of spray on SILICON LUBE not wd40 which will definitally effect any plastic it makes contact with, trust me from experience. Then after the oily lube was applied i used a 5.5 mm wrench and loosened both nuts on either side just a turn, maybe less for yours. This allowed the lube to penetrate. Then laastly i applied SILICONE GREASE, both found at home depot. The grease helps maintain the lube that has penetrated the hinge. then re-assemble the covers and presto- saved about 100 bucks on new hinges.
Was this helpful?
Yes
No
Solution #2
posted on Apr 13, 2009
Not Rated)
Deeds69
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Solution #3
posted on Sep 19, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
dont turn to hard they will break only solution i know is to look on ebay for new ones man
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
my mpc t1200 wont charge and also when it was charging before the AC/DC jack would always get really... (More)
Answer
i can not seem to copy dvds onto my hard drive to burn them/legally of course
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
