Related Tags:
This problem should be removed because:
Problem with Maytag MBF 2256 Bottom Freezer Refrigerator
ice maker. just installed water line. it was never hooked up.is there a reset? Water is not entering ice maker.
Solutions (1)
Best Solution
Wait a while for the ice maker to cycle 2 or 3 times. It ain't instantaneous.
Suggested Solution (1)
At the back bottom of the fridge there will be a coil solenoid. If your appliance is ice make ready this will be there, these coils have a bracket that has fitting for a water connection. Get a 1/4 tube with a ferrell and nut. slide them on the tube and connect to the fitting.
Sorry for the terminology. In the back of the fridge, if it has an ice maker kit already installed, there should be a bracket with a plastic thing with a round cylinder that has a couple of wires connected to it. This bracket has a small fitting that is threaded. The wall behind your fridge should have a water valve. You need to connect a pipe or tube from the valve in the wall to the bracket fitting on your fridge. There should be no special things needed except for a wrench to tighten the nuts on the tube. I don't know what kind of thing you have attached to the end of your water line, but if its suspect, remove it, if you can, and take it to Home Depot, Ace or wherever, and ask then to give you a flexible line with the right size fittings on each end. Most of them carry these hoses for ice maker kits. Some teflon tape on the threads cant hurt, but most times are not necessary. connect the water line to both the wall and fridge, tighten with wrench.I hope this helps.
HOOK UP OF ICE MAKER TO THE WATER LINE
how to hook-up the ice maker to the water line 1998 double door with water and ice through the door frs22zrf i need to know where water...
Ice maker not making ice after replacing water...
Water line had rusted out at water hookup source in the wall. Replaced the water line. It was making ice prior. Not making ice now & it...
I have a Jenn-air (JS48SEDBDA)
I have a Jenn-air (JS48SEDBDA) Refrigerator, that's been in storage while I remodel my kitchen. I'm ready to re-install it and...
my LG refrigerator has the
my LG refrigerator has the ice maker hooked up to the hot water heater, is this right. MY HOT WATER HEATER HAS SLUDGE IN IT THAT IS GOING...
Add Your Solution
Related Topics
Fix-O-Meter
59
59 people viewed this problem
- 1 person found this problem to be helpful.
- 2 people are following this problem
Top Maytag Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Thanks. I was going to let it cycle and come back to in a couple hours and see what happens.
It will take 24 hours to really get some ice in there on startup.
View More Comments
