Question about Yamaha Dtxpress Iv Special Electronic Drum Set
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
I am trying to find out what could be causing the high hat to malfunction. Cables are properly attached. Thanks.
  • 1 more comment
  • Bazman2 Oct 04, 2008
    I can't get the high hats to sound closed either
  • yuri59 Nov 12, 2008
    you have to press hi hat pedal too strong to get sound of close hi hat
  • Anonymous Dec 14, 2008
    i have the same trouble with the dtx iv . i can't get it to sound like a high hat.
Solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Posted on Nov 13, 2008
Make sure the sound module is correctly set for the SPECIAL kit and not the STANDARD kit. Press SHIFT and DRUM KIT and select a SP setting not a STD seting, ie SP Dyna.
Posted on May 05, 2009
If you have the SPECIAL version of this drum kit, it has a different hi-hat controller(the RHH) than what is default in the module. Reset the pad for the hi-hat to read RHH and this will cure any and all problems. It will function and sound just like a real hi-hat.
Posted on Apr 22, 2009
    Novelist:
  • 130 Answers
What is it doing? No Sound? Intermittently clashing by itself? A totally different sound [deviation from normal program], etc....
Posted on Sep 29, 2008
  • Chris G Nov 04, 2012
    When Iput oressure on the pedal to close the high hat it works ok sometimes but other times it makes the sound that is open. Also if I go into ceck the volume it shows it is open and not closed at times even though I have the pedal depressed.
In some pictures for the Yamaha DTXpress IV Special, the hit-hat has this trigger system under it and other pictures don't.What is it?
I see pictures that show an extra device beneath the Hi-Hat and the ads mention a "stereo hi-hat controller"... on the RHH130 there is a clutch to improve the feel of the Hi Hat... I think this is what you see in some ads.
Cut and paste:
This hi-hat pad design attaches to a standard hi-hat stand. Inside of the pad is a sensor system and built-in hi-hat clutch that feels,realistic when pressed. The RHH130 also features a dual zone design consisting of pad and edge sections that offer greater dynamic realism. The pad can also produce a foot splash.
Jul 23, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
I have a problems with my HI-HAT control. When I put a pedal for HI HAT controler down, you can play HI HAT, but in the next 20 second the pedal not choke HI HAT cimbal...What can i do? Thanks
Verify that the pedal is the CORRECT type for what you are using it for.
Pedals came in MANY varieties. I would ask the store where you got the items about it.
Pedals can be switch type either normally open or closed, Variable resistance/volume control, pulse type like the kick drum pedals that generate a varying trigger pulse...
My hihat controller has a problem sounds become
Make sure you aren't mixing up the cord for the hi hat pad and the hi hat controller.
Jan 17, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha dtxpress iv standard
try a wooden snare, a light kick drum, the most natural hi hat you can find, some soft cymbals and a selection of wooden and metal percussion instruments.
Dec 25, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Problems with DTXpress III special bass drum pad
If you are comfortable with working on it and the warrantee is up try taking the pad apart to see if the piezo element has come loose from its mounting or if the solder joint is loose. If that isn't the problem save your settings and initialize the set according to the instructions in your manual.
Aug 09, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Hi-Hat not always working with controller
youll need to change the sensitivity on the brain and all will be good
Jun 14, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Hi-hats
Here is a video detailing how to do this: Click Here
Apr 25, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
My Bass Drum trigger just stopped working .
this is an easy problem to fix. The piezo piece on the inside of your bass drum trigger uses a double sided tape that is fixed to a metal disc. the piezo trigger just fell off. mine did the same thing. I actually glued mine with epoxy and have not looked back.
Nov 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
3,555 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
