Question about DSC GESTETNER - DSc38uD Color Printer
Yes i have problen with my nitendo ds are not the problem
My Nitendo DS lite does not charge, the orange light does not turne ON when I plug the charger. I measured the voltage on the contactes of the DS lite when the charger is plug in and without batterie and...
Well the charger shouldn't be showing voltage if it's not plugged into the ds as the circuits not complete. And if you only recently dropped it in water, take the battery out and make sure there's no games in it and let it dry out for a few days. Also, make sure the cover for the gameboy game slot is off. Hope that helped!
May 08, 2011 | Nintendo DS Lite Console
Screen cracked when dropped. can I sent it to get fixed?
Nitendo/You can goto Nitendo.com
Good Luck and Happy Gaming-Koscoe
Oct 15, 2010 | Nintendo DS Console
Nitendo DS lite how to play music using R4 revolution DS on my
First you need to make sure you have the current firmware for the R4 card loaded onto the micro-sd card. I know that some R4 cards only accept up to a 2gb memory card so check and make sure you are using the correct micro card with the R4. When you have downloaded the firmware for your card you need to make some folders. Label them games...movies... music... etc.. making a folder for each one. Put the Mp3 files in the correct folder. When you use your R4 you will see three icons at the startup screen go to the one labeled multi-media... Moonshell will run the movies/music... you are ready to go ... hope this helps
Dec 09, 2009 | Lego Media Video Game Consoles & Games
When i turn on my DS the top screen is blank then it turns white and stays like that, i don;t know what's wrong
If your booting to a GBA game, there us a setting in the machine BIOS to tells it to use the top or bottom screen. You can access it by taking out the games and booting the unit.
If your booting a DS game, it should display on both. If not, it is possible a wire has come loose on the display (or the screen went bad).
You can try and check for the wire yourself or take it to a repair shop. If you bought it recently call Nintendo.
Nov 01, 2009 | Nintendo DS Lite Console
Can you get internet on ds?
Courtesy of Blurt It: http://www.blurtit.com/q871390.html This explains how you can get internet access on your DS. It is possible.
Jun 12, 2009 | Nintendo DS Console
Purchasing Games for Nitendo DS - Machine purchased from NZ
name
address
credit card information
shipping address
possibly email address
Jul 26, 2008 | Video Game Consoles & Games
Mic problems
my ds was woking fine and then i turned it off and it would not turn back on
May 13, 2008 | Nintendo DS Lite Console
Reseting the DS system to default
can u help me how to resetting at nitendo ds??? plz help me
Nov 17, 2007 | Nintendo DS Console
66 people viewed this question
Top DSC Office Equipment & Supplies Experts
k24674
Are you a DSC Office Equipment and Supply Expert? Answer questions, earn points and help others
