Question about Gaggia Titanium Espresso Machine
Inconsistent quality of crema and coffee
I have attended a barista course and understand how to use my machine, however, one day my coffee will be perfectly brewed with a lovely topping of thick crema yet other days the coffee will be weak, muddy, with virtually no crema, yet I follow exactly the same proceedure each time. It seems that the coffee is brewing perhaps 'too quickly', please advise.
  • Gaggia Master
  • 19,396 Answers
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
Dispenses very little CREMA. Is there something to adjust?
Rule of thumb - espresso machines deliver a shot of coffee in 25 to 35 seconds.
If there is no crema and the coffee comes faster:
  1. There is not enough coffee in the portafilter (7 grams per shot).
  2. The coffee is not tamped enough (about 30 lb pressure on the tanmper handle).
  3. The grind is too coarse.
If the above does not "fix" the crema problem, post again and include make and model of the machine and type of portafilter.
Good luck.
Apr 27, 2015 | Coffee Makers & Espresso Machines
My bes870 will not create enough pressure to form a good crema ,grind setting is 2-3 .Amount of ground coffee is correct but the pressure does not go much past the pre fusion pressure .The machine has...
For an 8 month old machine it should still be under warranty unless commercial use. (similar unresolved Q posted http://www.fixya.com/support/t20409606-get_pressure_up).
Jul 20, 2014 | Breville Barista Express Espresso Machine...
My Coffee machine Delonghi doing expresso without foam today. Before doing good expresso with foam. help please.
Espresso should have crema not foam, foam is air added to coffee, like Starbucks does. Issue lays in the grinder and coffee quality. Recommend using Italian espresso bean like Miscela d Oro
Apr 14, 2014 | DeLonghi Coffee Makers & Espresso Machines
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
I have an old Starbucks Barista Athena Espresso maker. It has worked like a charm until last night. Everything works correctly until I start to brew the espresso. The green light is on and the green light...
I just had my Barista Athena do the same thing. My son took the the coffee basket holder apart, nothing wrong there but the gasket on the bottom inside of the holder, where the coffee basket fits, is compressed letting the basket sit too close to the bottom of the holder. He tested this by raising in the basket and got coffee to flow ever so slightly. I just happened to be looking for a new gasket and saw your post.
It is my understanding that Starbucks is no longer making coffee machines. Your best bet is to contact Starbucks and ask who they may be recommending for repair support.
I hope this helps.
Jan 03, 2011 | Estro Barista Athena
New machine but no crema.. very disappointed
I have the same machine with excellent crema. You need to be sure you are using a high quality burr grinder on the fine setting. Also be sure to tamp using a tamper for even compression. The espresso should come out SLOWLY and smoothly... it will end with a great crema.
Jul 28, 2010 | Rancilio Silvia Espresso Machine
Saeco Italia Digital Barista Fully Automatic Coffee Machine: I've had an Italia Digital for ~3 yrs. I keep it w...
Could be the burrs on the grinder are dull, instead of nice ground coffee it is producing crushed coffee.
May 18, 2010 | Starbucks Saeco Italia Digital Barista...
Virtually no crema :-((
If you have tried different coffees and grinds then i would try different packing methods using a tamper to do so. Try packing very firmly to not so firmly and see if that works. Also you might find that you need a new double filter basket. I have seen this in quite a few machines where the holes in the basket can become very slighty enlarged from what they were originally and what this does is allows the coffee to flow through the basket too quickly and therefore leaving you with poor crema by not getting a good extract from the coffee. I hope this helps.
All the best
Mr La Pavoni
Apr 23, 2010 | La Pavoni Europiccola EPC-8 Espresso...
GAGGIA TITANIUM........WEAK COFFEE
Try adjusting the grind finer, if that does not help then go to menu and make sure pre infusion is enabled.
Jan 19, 2010 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
191 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
