My model#46h84 tv shuts off after a couple seconds and the red light next to the power button blinks. sounds like this is not an uncommon thing. its football season, please help! thank you. its a toshiba by the way.
  • aristia Sep 19, 2008
    experttv,
    Thanks for responding! I'm not familiar with a meter and solder, but I have a good friend who is an electrician. Is that something he would have? Or is it related to TV's only?
    What is the convergence circuit? Is replacing the power supply something we could do ourselves, or would we have to pay big bucks for someone else to do it?
    Aristia Hummel
    Novelist:
    Champion:
  • 203 Answers
There are several things that can cause this problem. The most common is the convergence circuit, the other common problem is the Z801 module in the power supply. Do you know how to use a meter and solder?
Tim Nolan
Posted on Sep 19, 2008
  • experttv
    experttv Sep 19, 2008
    If you are not expereienced with soldering and a meter you most likely will need to pay big bucks to have it done right. The repair should run you $300-$500 depending on whats wrong and what area you are in.
    Tim Nolan
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
SCreen turns red then shuts off
The 46H84 has 3 CRTs instead of a lamp. Red, Green and Blue. Your red CRT is shorting out shutting down the set.Here is how you test that theory. Remove the speaker grille, there will be an access panel behind the grille remove that and you will see the CRTs red is usually on the left. hit the power momentarally to locate which tube is red. then power down and unplug the power cord. Carefully remove the tubes Circuit board. ( you may have to carefully slice the glob of silicone applied at the factory to get the circuit board off) Once you have the circuit board off the Red CRT make sure it isnt touching anything and try powering up the set. If the set stays on and the other 2 CRTs light up. That tells you the RED crt is shorted and thats whats shutting your set down. Let me know if I can assist you further.
Mar 25, 2008 | Toshiba 46H84 46" Rear Projection...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Electro Med Services...
