Question about MSI Computers & Internet
My pc gives 4 double beeps on bootup MSI MS-7100(v1.X) ATX Mainbourd can someone tell me the problem as do not have the manual
    Sergeant:
    Champion:
  • 258 Answers
I think it's the memory try this:
remove the memory(the one rectangular chip attached in the mainboard) then clean the contact using eraser then reattach it
Posted on Sep 19, 2008
Ms-7100
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Realtek-AC-97-Audio-Driver-for-Windows-7.shtml
Mar 05, 2013 | MSI : K8N NEO4 Platinum SLI/S939/nForce4...
Please, I am need manual mother board MSI G31M3-L V2. Obrigado!
http://www.msi.com/service/download/manual-8486.html
then select US
see page 1 of pdf document.
INTRODUCTION
Thank you for choosing the G31M3 V2 Series (MS-7529 v1.x) Micro-ATX mainboard. The
G31M3 V2 Series are based on Intel
® G31 & Intel® ICH7 chipsets for optimal system
efficiency. Designed to fit the advanced Intel
® CoreTM 2 Duo/ CoreTM 2 Quad/ Pentium
Dual-Core E2XXX and Celeron 4XXX/ Wolfdale Series LGA 775 processor, the G31M3 V2
Series deliver a high performance and professional desktop platform solution.
Apr 24, 2011 | MSI G31M3-L V2 Motherboard
I wanna connect my mainboard to a power but i dont know how
Motherboards can look a bit daunting at first, but they're not really. You question is quite broad, so I'm going to refer you to the manual. First, there is both a version 1 and version 3 motherboard. You'll need to determine which you've got to download the correct manual. Look closely at the board between the YELLOW and WHITE bus slots. You should see some printed text. "MS-7125 V1" or "MS-7125 V3". The V1 or V3 tells you which version you have - either 1 or 3. Download the appropriate manual by clicking the version link: "V1" or "V3"
Unzip and double click the .pdf file inside to open it in Adobe Reader. The manual will display on the screen. Read or print it in its entirety. Pay particular attention to the Hardware Setup chapter (chapter 2 in the V1 manual) and any other part you're not sure about. Rather than me typing all of it in here, you should print out the section (if you haven't printed out the whole manual) and follow it. It goes step by step - one at a time. Skip over parts that are already done, and go to the next.
If you have specific questions about a particular step - ask a question here and I'll answer as best I can for you.
Please rate this reply - thanks!
Dec 02, 2010 | MSI K8N Neo4-F Motherboard
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
How mutch RAM does "Motherboard MSI PM8M3-V (MS-7211 v1.x) Micro-ATX" supports
Spec sheet shows you can run 2GB of PC2700 DDR RAM (DDR-333), or PC3200 DDR RAM (DDR-400); http://www.superwarehouse.com/MSI_PM8M3-V_Micro_ATX_Pentium_4_Motherboard/PM8M3-V/ps/727805
MSI also provides a list of tested memory for the board;
http://www.msi.com/uploads/test_report/TR10_234.pdf
Hope you find this helpful!
Mike
Oct 12, 2009 | MSI PM8M3-V Motherboard
Replace motherboard
There is no need to get an exact replacement motherboard, most likely it is out of production if it is more than 6 months old.
The desktop case has and motherboards have standard configuration mounting holes. I sugest you work out what your computing requirements are and go to your friendly computer shop and purchase a motherboard.
Most of the existing components will be compatible but the RAM and CPU may not, you need to check this out.
Sep 10, 2009 | MSI K8N SLI Platinum Motherboard
Manual motherboard msi (ms-6547) ver 2
There are 5 versions of this model
http://global.msi.com.tw/index.php?...
They have either 5 or 6 PCI slots.
Find the version number - beside the model number
Note the SiS main chipset numbers (one may be under a heatsink)
MS-6547 Ver 1.0 a.k.a. 645 Ultra - ATX, 5 PCI slots
SIS® 645 Open Architecture DDR333 Chipset
SIS® 961 MuTIOL® Media I/O Chipset
MS-6547 Ver 2.1 a.k.a. 645 Ultra-C - ATX, 6 PCI slots
SIS® 961B MuTIOL® Media I/O Chipset
MS-6547 Ver 2.0 a.k.a. 645E Max - ATX, 6 PCI slots
SIS® 645DX Chipset (under heatsink)
SIS® 961B Chipset
MS-6547E Ver 1.0 a.k.a. 645E Max-C - ATX, 5 PCI slots
SIS® 645DX Chipset
SIS® 961B Chipset
MS-6547 Ver 2.2 (2.1) a.k.a. 645E Max-U - ATX, 6 PCI slots
SIS® 962L Chipset
Jun 27, 2009 | MSI MS-6547 Motherboard
How to connect ATX PWRSW to K8MM-V (MS-7142) board
You have a MSI mobo - goto the URL listed below, you will find everything there is to know about it there. Best.... PCrx4u
http://www.msicomputer.com/product/p_spec.asp?model=K8MM-V
Dec 29, 2007 | Computers & Internet
Computers & Internet Logo
81 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
