Television just went off and won't power back on
My 52 inch 1080 mitisubishi digital tv just went out I recieved it as a gift it was on for two days and i was trying to set channels and instead i locked the front panel tv went out, friend said she no longer have the manual for the tv to reset the code, i bought a universal remote but it's still not coming on plug it up and green light come on and under the on and off button it states timer, gives to blinks and never come onh
Posted on Sep 21, 2008
Heard a pop, tv went off, and it won't power up
Power supply in most cases and a lot of the time the part is under a heat sink where you cannot see it.
You might have more help if you posted the question again with the exact brand and model number.......
Dec 12, 2012 | Televison & Video
Tv won't power up after power went out
Most likely your TV's power supply was damaged with the power surge. You will need to take it to a repair place and have the supply checked out and find out the cost versus the value of the TV. I hope this helps.
May 01, 2012 | Toshiba Televison & Video
WS-65511 won't turn on
Hello
The power supply section to your set has the fault. If you come over me by Fixya paid service purchase, I'll assist you to repair your tV by yourself at home. OK.
Dec 07, 2011 | Mitsubishi WS-65511 65" Rear Projection...
The power in our bar went off last nite and now one of the tvs won't cut back on. No power at all. Any ideas? Thanks
COULD BE ON SPERATE BREAKER. BREAKER COULD HV TRIPPED FROM A POWERS SURGE WHEN POWEER WENT OFF OR CAME ON. CHECK BREAKERS IN PANEL
Dec 04, 2011 | Sanyo Televison & Video
I've owned for approx 3 yrs. Today I was watching a show on my Panasonic TH-50PZ80U and all the sudden the sound went away. From the lowest volume setting to the highest, no noise at all...Please...
Hello!
First move: unplug your broadcast provider's box, wait for a minute, then plug it back into power source. I mean: leave all the connections intact, just unplug from power source. It might be just power cord or power adapter. If that's not the case, please do the same with TV. Unplug it from wall outlet, wait a minute, plug it back in. It's a next step, if your "box" won't take care of the problem. If that won't take care of the issue, refer to owner's manual for "reset" procedure. Worst case scenario: you might need to replace main board inside or your TV.
good luck,
Thanks,
Alex.
Oct 09, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Tv went off won't come back on
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, If otherwise you contact the manufacturer or a skilled qualified personnel to handle the fault..
Hoping that will help to solve the problem....
Jun 14, 2011 | Vizio L32 32 in. LCD HDTV
Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Aug 24, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
