Question about Acer Aspire 5315 Notebook
Installation of Vista
Hello,I bought today new aspire 5315 and the Vista started to install,it was copying some files and then it started to format harddrive,but it stopped on 50% and restarted itself. When I switch it on it writes,reading error HDD. I was trying everything from recovery,which I did not find to BIOS,what is happening?
  • hauz88 Sep 19, 2008
    why does not the alt+ F10 while acer logo shows works?
  • 2,794 Answers
Try letting it run one more time. If it does the same thing, the hard drive needs to be checked for a possible replacement.
Posted on Sep 19, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
Most probably hard drive issue .you should get in touch with vendor to get it replaced
I can install Ethernet controller on my aspire 5315 . i have downloaded the installation but i cannot find the setup . i
Go to Start Menu: in the search bar type: Ethernet, Ethernet Controller, or Controllers.
Jan 18, 2011 | Computers & Internet
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
I cant format my acer aspire 5315, have to fomat it becouse my compute wont log into windows becouse a saystem driver is missing or hurt. Can anyone please help me so i can re install wimdows vista basic?...
yes you need to format, you need the cd for do this, download with another compuiter and use your key password, look under the laptop the key number is your licence
Aug 04, 2010 | Acer Aspire 5315 Notebook
Bootmgr missing
format ur laptop and solve ur problem
Sep 05, 2009 | Acer Aspire 5315 Notebook
Can I install xp to my acer aspire 5315 .. it has
Go to this link & I'm sure it could solve your problem... Trust me... :-)
http://www.laptops-drivers.com
Jul 12, 2009 | Acer Aspire 5315 Notebook
I got Acer Aspire 5315. I am facing 2 problems. Code 39 and Code 28. Can anyone give me an advice for fixing up this problem. Thanks
this is a software issue with the SP3 installation. It can be fixed by formating your harddrive and reinstalling the operating system you are currently using. Or you can use VISTA.
Feb 28, 2009 | Acer Aspire 5315 Notebook
Installation problem
Hay
May be your Windows DVD/CD is Corrupted.
or
May be try to format your hole harddrive and then install a clean copy of windows.
I am pretty sure this will work.
If not give me message.
Jan 19, 2009 | Acer Aspire 5315 Notebook
Acer Internet Problem.
go to the Acer website and download the drivers for your make and model laptop if you do not have  teh original driver disks that came with your computer.
If the computer has a recovery partition, check and see if one of the recovery options allows you to restore drivers only.
If your acer cannot access the internet because you do not have drivers for the direct or wireless network connections, you can still access the make and model support and drivers files from the Acer web site and burn to a CDROM or save to a jump drive to install on your laptop - or you can request a driver CD for a small $$ from Acer.
Dec 10, 2008 | Acer Aspire 5315 Notebook
Resource cd for aspire 4315 laptop PC
Some Vista driver may work on XP, however, to avoid any risk of getting in troubles with your Windows xp installation, you can download drivers and utilities for XP starting from this page.
Regards
Jun 08, 2008 | Acer Aspire 4315 Notebook
Installing XP/downgrading from Vista
you can not install under windows environment if it is a down grade. i thought maybe that is how you are doing because you said when you click intall...?? you have to boot your XP home from the cd drive and there you follow the instructions on how you wanted it installed. in XP series, you only get to use the mouse when windows is almost ready for intallation. but initial setup is in DOS mode only.
Apr 07, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5315 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
