Question about Sony MHC-GX450 CD Shelf System
Mini hi-fi component system mhc-gx450
Mi estereo prende pero no le funciona ningun boton
  • jaimehernand Sep 19, 2008
    alguien sabe espanol
  • 1066 Answers
SOURCE: How do I connect ipod to sony MHC GX450
you can buy a Belkin docking station for about $20  or you can buy a headphone to RCA plug connection wire.  I like the docking station as it has a remote and charges the ipod as well.  Shop ebay
Posted on Mar 27, 2009
  • 822 Answers
yes you can connect using rca phone jack to rca jack it depend on what cable you use from your ipod. connect from your ipod audio output to auxillary of sony mhc-gx450.
Posted on May 31, 2009
  • 2071 Answers
SOURCE: my sony MHC-GX450 has power but does not function,
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC and also all component parts joint in power amplifier section if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
Posted on Jun 11, 2009
  • 10594 Answers
SOURCE: I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Posted on Nov 25, 2009
  • 62 Answers
SOURCE: sony mhc-gx450 cd player is not reading.I used a cd cleaner and d
First unplug the unit and press the power button to make sure all the power is out of the unit. Try to take a cotton qtip and clean the lazer lense with alcohol. after wipe it clean with a new cotton qtip to remove the film the alcohol produces. Do not use a lot of alcohol and drip it all inside of the unit though.
Also if you tried a cd-r try a real copy instead. Make sure your cd's are ok.
Good luck.
Posted on Feb 16, 2010
MHC-gx450. Why won't the tray open?
Apparently a mechanical issue. Cannot tell you without looking at it. Sorry.
Jun 20, 2015 | Audio Players & Recorders
My subwoofer for my sony mini component system mhc-gx450 will not work any sugestions???
Is the LED on the front of the subwoofer unit glowing?
If not then check that (a) the plugs are correctly inserted in the two sockets on the back of the the mhc-gx450, and (b) check that the subwoofer is activated on the mhc-gx450 unit.
Oct 15, 2011 | Sony MHC-GX450 CD Shelf System
Mhc-gx450 trying to connect speakers how do i know which wire is which? i have a grey/black wire and a grey wire which goes in the black/red input?
I'm sorry for the difficulties you're experiencing in connecting the speakers to the Mini Hi-Fi System. Please see the below picture to view the connections.
I hope the information helpful. If you need any clarifications, please let me know. Thanks for understanding.
May 16, 2011 | Sony MHC-GX450 CD Shelf System
El lcd prende pero, queda como bloqueado, no me responde del panel de comandos ni del control remoto, solo puedo ver y escuchar en donde quedo sin ningun tipo de problemas.
Me parece que hay un boton que se quedo atorado y que no deja aceptar otras funciones. Por favor de verificar en el televisor si todos los botones de audio, channel, etc.. son libres.
Mar 13, 2011 | Samsung Televison & Video
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
Mi control de dish no quiere hacer nada quien me ayuda
Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Lamento escuchar que este teniendo un problema con su control de DISH Network, seria un placer asistirle proveyendole informacion que le sea de uso para resulusionar el problema. Si el control no esta haciendo nada primeramente debe asegurarse de que el control este en el modo de SAT significando que cualquier boton que oprima el control el boton de SAT en la parte de arriba se debe encender en rojo. Si ningun boton se enciende en rojo puede intentar poner baterias nuevas en su control, si no funciona significa que el control no sirve necesitaria uno nuevo, si el boton de SAT se prende en rojo puede intentar reprogramar el control a su recibidor. Para hacer esto tiene que accesar la pantalla de System Info en su televisor, puede hacer esto oprimiendo el boton de Sys Info enfrente del recibidor. Despues en el control va a oprimir el boton de SAT hasta que los demas se enciendan rojos cuando vea que se encienden rojos ingrese un numero entre 1-15 seguido por el signo de numero (#) y el boton de record una vez. Trate el control deberis funcionar. Tambien puede entrar a nuestra pagina web aqui encuentra ayuda en como arreglar el control y el procedimiento. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH gracias espero esto le ayude.
Feb 09, 2011 | DISH Network IR Remote Control
No funciona
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Sony MHC-GX450 CD Shelf System Logo
65 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
