Question about ASUS A7N266-VM Motherboard
ASUS A7n 266 VM Sound Problem
While fitting a PCI Card the sound plug was dislodged from its pins, located by the PCI cards. The order of the pins was lost. Can I get the correct pin placement please.
b.watt@xtra.co.nz
Regards
Bernard Watt
    Problem Solver:
  • 4 Answers
I think you are refering to the front audio pin that are dislodged. Refer to your user manual for the pinout diagram, If there is some other problem get back.Thanks
Posted on May 12, 2009
    Problem Solver:
  • 6 Answers
Just call the place where you bough it
Posted on Sep 04, 2009
Motherboard model : P5PE-VM Problem : need a sound card (asus)
Any brand inexpensive PCI sound card will be adequate. Remember to first enter the MB bios and disable the onboard audio first. You will now only be able to connect to autio ports from the back... front will no longer work.
Sep 12, 2011 | ASUS P5PE-VM Motherboard
Compatible memory at 2gb capacity and video card for asus p5pe-vm motherboard
Hi, you can download a manual here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR RAM memory
1 x AGP 8X slot.
Hope this will help you.
Aug 14, 2011 | ASUS P5PE-VM Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
How to install sound driver of asus p5gd1
NEED TO KNOW IF YOUR USING THE SOULD CARD BUILT ON THE MOTHERBOARD OR A PCI card if your using a pci card you have to disable the on board driver, if you want the onboard sound card to work you have to go to bios and turn on sound card, once it's turned on reboot an you should not need the driver unless the biso battery went dead, if thats the case you can go to http://www.asus to download the driver.
Jun 13, 2010 | ASUS P5GD1-VM Motherboard
Helo mr
Hello you mainboard support Memory configuration:
Dual-channel memory architecture
4 x 184-pin DIMM sockets support up to 4GB of unbufferred non-ECC 400/333/266 MHz DDR DIMMs
so it wont support DDR2
and for the VGA
it is
1 x AGP 8X
so you can put only up to vga card to 8x and no pci express or something like that WILL NOT BE COMPATIBLE TO YOU BOARD
OK
CHEERS
UTTAM
Jan 22, 2010 | ASUS P5P800-VM Motherboard
What sound card is compatible with my asus p5vd2-vm se im going to buy a altec lansing 6 channel speeaker pls. help
Your ASUS motherboard model has on-board sound. You are asking what 3rd party card to install?
Your motherboard supports:
PCI
PCIe x1
PCIe x16
A 3rd party sound card of your choosing that will fit in one of these vacant slots will do nicely.
Jan 02, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
Feb 11, 2009 | ASUS P5S800-VM Motherboard
Case front firewire port to motherboard connection???
Yeh dont plug it into a USB header...
yes if you buy a PCI firewire card they will have 1 or 2 headers on the card so you can fit your front Firewire port to it...
[Belkin cards 99% of the time have headers on the card]
Let me know...
Matt
Jan 22, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
INFORMATION ====== ASUS A7N 266 VM MOTHERBOARD
go to asus website:
Apr 20, 2008 | Computers & Internet
ASUS A7N266-VM Motherboard Logo
330 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
