Question about Bose 3 2 1 GSX System
Dvd tray won't eject...system says it is "opening" or "closing" but no action.
  • darreneng Oct 24, 2008
    we have same problem. seen others in forum with it too but no answers yet?
    Problem Solver:
  • 4 Answers
Check other postings of this same problem...wish I could merge this with the other.
Fix is basically to unplug the unit and let power down for 1 minute. I even pressed power button to make sure it powered all the way down. This resets the unit. Then after plugging in but before turning back on Press the Eject button. My disc ejected right away, but the other solution says it will eject after you turn it on. Hope this helps.
Posted on Oct 24, 2008
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
My dvd wont play on laptop
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Jan 28, 2013 | Compaq Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Dvd door won't open for Sanyo DVW 6000
If you are trying to eject a disc, look closely at the front bezel of the drive, there is a small hole near the eject button, push a paper clip into the hole (straightened paperclip) and the tray will be ejected.
If the DVD door is stuck and will not open through ejecting via the icon in My computer, or the eject button on the bezel will not work, you likely have a faulty drive that will need to be replaced
Jul 22, 2011 | Computers & Internet
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Original Xbox disc tray not opening properly
I found this posted on cheapassgamer.com
Greetings, Ladies and Gentlemen.
Since I was able to solve my Xbox's tray problem completely (for now) due to this site, I felt it necessary to contribute to the forum, in order to (hopefully) help the next person with the same problem.
First, let me note that my Xbox has a Samsung drive. This method may only work if you have a Samsung or Hitachi drive, as they have the lever action emergency release.
Issue:
A) Xbox DVD tray will not eject when eject button is pressed, instead making a clunk / thump noise, as if being blocked from ejecting due to media inserted incorrectly – irregardless if media is present in the tray.
B) Tray will sometimes eject if button is pressed multiple times.
C) Tray will only eject if Xbox is thumped upon directly above the tray.
Solution:
A) First, go to http://www.xbox-mod.co.uk/index.php?...mergency-eject . Then, scrounge up a paper clip and proceed to manually eject your DVD tray.
B) Next, remove the Xbox logo front panel from the DVD tray. This is fairly easy to do, but you must be gentle, or you might break the tray or the front panel. The way to remove it is to take a pair of needle nose pliers and use them to gently pull the bottom clips away from the tray's underbelly before pushing the front panel up. You can also unclip one side, then the other if you are having difficulty.
C) Use the eject button to close the tray. Now open it again. If it still refuses to open (as did mine), use the paperclip and manually eject the tray.
D) Now, loop your finger through the open DVD laser slot in the tray, and gently pull the tray towards you – it will come out a wee bit more, and then stop. Do not force the tray to extend any farther than that.
E) WHILE THE DRIVE IS STILL OPEN, use your paperclip on the manual eject lever. It may take a moment to trigger it, as it is currently depressed, but if your Xbox and DVD Rom are like mine, it will actually draw the tray back in.
F) Poke the Eject button. It should pop open without any argument at this point. Try it a few times, just to be sure, if you'd like. Then, slide the front panel back onto the tray, and you should be good to go… until the next time the P.O.S. decides to slip a gear.
What's that? Slip a gear? Yep. As far as I can tell, that's exactly what is causing the trouble with the drives. Pushing them closed with your finger will force the motor to engage, yes? Well, eventually it seems the cheap DVD Rom's in the Xbox get fouled up, the motor kicks in a bit too late, closes the tray too far, and slips a gear. Then it will clunk / thump at you impotently until you fix it. What we have just done seems to reset the engagement point on the motor, and allows the eject button to work properly again. An easy solution to this problem is to always use the eject button to load and eject media, but you can't always ensure your guests are going to adhere to that policy (Or that the Xbox won't pull it shut too hard just to spite you, the foul tempered little…).
For Thompson and Phillips Drives, that use a gear to manually eject the tray, I would assume that pulling the tray forward, then advancing the gear manually until it refuses to do so, and then pushing the eject button might work. If anyone tries this and succeeds, reply to this message and let us know.
Thanks again for leading me to my solution (even if it may only be temporary), and I hope my suggestions have led you to yours."
Hope this helped please rate.
-Ryan
Feb 19, 2009 | Microsoft Xbox Console
Dvd try stuck
dvd tray will not eject...system show "opening" or "closing" but no action
Sep 19, 2008 | Bose 3 2 1 GSX System
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Bose 3 2 1 GSX System Logo
147 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
