Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson stylus cx 7400
Hi, i have an epson cx 7400 all in one printer, and I can't find the ink changing button, nor can I figure out how to remove or put in new ink cartridges due to the fact that I can't find the button. Can you help fix my problem. Thank You.
  • 2 more comments
  • sophiaanne Oct 10, 2008
    How do i get the ink cartridge holder into position for changing inks?
  • lardeb Dec 02, 2008
    I have replaced the black ink cartridge, the others are low and I don't need the color ink....but my low ink/stop button will not stop blinking and the power on button keeps blinking. I have tried turning off and on, nothing works to reset the printer in order to print. Help
  • Anonymous Dec 10, 2008
    Direction to load black ink.
  • Anonymous Dec 20, 2008
    I do not have a "maintenace tab" in this section. I can't get the light to turn off either.
Epson includes step-by-step instructions on changing the ink cartridges in the Printing Preferences menu:
Click the start button and open the Control Panel.
Right click Printers and select Printing Preferences.
Click the Maintenance tab.
You should see a button that says Ink Cartridge Replacement.
Just follow the instructions and it walks you through it.
Posted on Nov 25, 2008
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a27
Posted on May 24, 2009
SOURCE:
How to change the ink cartridge on an epson cx 6000 printer
Here is a link to your users manual, if you lost yours. Page 14 explains how to replace the ink cartridge.
http://files.support.epson.com/pdf/cx6k__/cx6k__pg.pdf
Hope this helps...
Sep 14, 2009 | Epson Stylus CX6000 All-In-One InkJet...
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    E-90 error message on Epson CX6000
    If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
    If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
    1. Turn off the Stylus CX.
    2. Lift up the scanner.
    3. Press down on the ink cartridge cover to make sure it is completely closed.
    4. Close the scanner and turn the Stylus CX back on.
    Also
    If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
    2. Lift up the scanner to access the printer area.
    3. Remove the tape from the ink cartridge holder.
    5. Close the scanner.
    6. Turn the Stylus CX back on.
    Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    HOW TO CHANGE THE INK FROM THE PRINTER EPSON
    You have to lift the whole top up. It should liftup under the scanner bed. Inside you will see five seperate in cartidges. I suggest you buy them from ebay.. You can get them pretty cheap...Please give good rating...It is important
    Aug 01, 2009 | Epson Stylus CX4800 All-In-One InkJet...
    Black ink not printing
    You have to run a head cleaning cycle:
    Follow these steps to clean the print head:
    1. Make sure the Stylus CX is on and the cp_light_183_er.gif ink light is off.
    2. Hold down the cp_button_48_er.gif ink button for 3 seconds until the cp_light_1.gif On light starts flashing. The Stylus CX runs a head cleaning cycle and the cp_light_1.gif On light flashes.
      alert_caution.gif Caution: Never turn off the Stylus CX while head cleaning is in progress. You may damage it.
    3. When the cp_light_1.gif On light stops flashing, turn off the Stylus CX.
    4. Load letter-size paper in the sheet feeder.
    5. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds. The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown below are some examples of what the nozzle check may look like:
      Nozzle check pattern with no gaps im_158_er.gif Nozzle check pattern with gaps im_159_er.gif
    6. Examine the nozzle check. If it does not look like the nozzle check pattern with no gaps as shown above, repeat steps 2 through 6.
    alert_note.gif Note: If you don't see any improvement after cleaning the print head three times, turn off the Stylus CX and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
    If you do not use your Stylus CX often, it is a good idea to print a few pages at least once a month to maintain good print quality.
    Oct 24, 2008 | Epson Stylus CX5000 InkJet Photo Printer
    Epson Stylus CX 6000
    Hi-
    There is an option on the control panel to change an ink cartridge after pressing menu button, go to maintenance and go to change ink cartridge. if you are having difficulties still, get back to me. thanks for using fixya. pls rate solution if it helps. keep me posted.
    Aug 17, 2008 | Epson Stylus CX6000 All-In-One InkJet...
    Changing Ink Cartridges
    I'm assuming you are using originals. I would suggest you taking the cartridges out and re-inserting them. If you are using refilled cartridges and you used the cartridges to almost empty then probably the chip may have short circuited rendering the chip useless. If you bought remanufctured cartridges I suggest you ask them for replacements. This isn't really that high tech but I hope this helps.
    Jul 15, 2008 | Epson Stylus CX6000 All-In-One InkJet...
    Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
    1,360 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Inky Fingers
    Inky Fingers
    Clive
    Clive
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
