Question about Audiovox FPE3206 32 in. LCD Television
Audiovox LCD FPE3206 problems
Tv was working earlier today. Turned off, came back from town. Turned on, power light turns to blue. But that's it. Can't get the input, menu, anything to come on to screen. Just black. Other devices, VCR, DVD will not play through it. Any idea??? Same problem here, except I have sound of tv, dvd, etc. with black screen. Less than 2 years old tv!
  • 1 more comment
  • tom solder Oct 03, 2008
    Mine is 3205. Started off with longer and longer time to turn on. Got the relay clunks when power button on remote was pressed, but no screen. Now won't power up at all. Had it maybe 2 years, maybe less. Bought it at BJ's club.
    tom
  • richard1177 Oct 21, 2008
    I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
  • Anonymous Mar 27, 2014
    When I turn on tv I get no picture. It takes me over one hour to finally get a picture. I go to input and enter DVD. I have to keep turning the tv on and off to get the dvd screen. HELP
Hi, All.
I ordered a new power supply module on ebay. Cost about 106.00 delivered. Came in a few days. I replaced the unit, bunch of screws, all wires were cable plugins, no problems at all.
After reassembly, it worked. What can I say? Sometimes ya just get lucky.
tom
Posted on Oct 21, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Change your inverter board
Posted on Sep 21, 2008
  • jkgracej2 Dec 12, 2010
    Replaced my inverter board and it didn't work! Sometimes you just get unlucky huh?
FPE3206 - I have blue power led lit and no pic or audio. Thought it was the inverter but wasn't. Power supply has 5v. Did not get the 24v reading. I have 2 bad surface mount resistors on the main....
The tv main Tuner signal board it is dead and it is the causes,if u have 2 burn surface mount resistors on it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole main Tuner signal board for the replacement.
May 31, 2011 | Audiovox FPE3206 32 in. LCD Television
Tv screen blacked out. no picture or sound. powers up blue led lights no remote response or menu options
hello,it's the I.C that got bad,so all you need to do is just to replace the bad one with a new one to have your TV powering on as normal,
please kindly rate this solution if it's helpful,
take care.
May 28, 2010 | Audiovox FPE3206 32 in. LCD Television
MY TV TURNS ON BUT NO PICTURE OR SOUND I HAVE A AUDIOVOX FPE3206 MODEL
you could have bad capacitors in power supply.You can probably see the they normaly have flat top.If top is round like a bubble it is bad.This is common problem with flat panel lcd tv and monitors
Feb 22, 2010 | Audiovox FPE3206 32 in. LCD Television
Tv screen went black and no sound
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. It sounds like at least you do have the 5V standby power supply working but the main supply is not getting the 'ON' command from the main board, or the power supply is gettin ght e 'ON' signal but failed to turn on.
Sep 25, 2009 | Audiovox FPE3206 32 in. LCD Television
When turned on it Flickers
Mine started out like that, now flickers about an hour before it comes on. I don't turn it off anymore, it'll burn out one of these days and I'll get a better TV.
Jan 01, 2009 | Audiovox FPE3206 32 in. LCD Television
TV Picture does not come on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Audiovox FPE3205 32 in. HD-Ready LCD...
Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
Oct 08, 2008 | Audiovox FPE3206 32 in. LCD Television
Flat panel tv
I had a similar problem, except I had sound and with a flashlight I could see audiovox when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Aug 16, 2008 | Audiovox FPE3206 32 in. LCD Television
Same thing here. Seems like there is an issue with the power supply. There is an interesting buzzing sound coming from the power supply. The power supply is located underneath the rear panel of the set. The panel is relatively easy to remove and it looks like the Power Supply would be pretty simple to replace.
Would like to know where to get a new one. This TV is just over a year old and out of the manufacturers warranty period.
If anyone else has tinkered around with this set and has any other incite to share Id be very interested in hearing it.
Thanks
MacPointMan
Jul 04, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Audiovox FPE3206
I had the same problem on my Audiovox FPE 3206, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Apr 22, 2008 | Audiovox FPE3206 32 in. LCD Television
Audiovox FPE3206 32 in. LCD Television Logo
905 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
