Question about Sony VPL-CX70 Multimedia Projector
Lamp timer of my Sony VPL-CX70
Hi there,i have 1560 Hrs in my projector , so i want to know is this the hours i have left it or is it 1560 hours i've used
Used
Posted on Nov 27, 2008
REMAINING LAMP HOURS
Press MENU on the remote (with the projector running of course).
In the window that comes up on screen, there are a series of icons on the left side of the screen, and the currently selected one will be highlighted (yellow if memory serves me correctly) scroll down through the icons to the very last one - the Information icon.
Press ENTER
The Lamp Timer (lamp hours) will now be showing on the screen, below technical info about the current signal feeding the projector. The 'Lamp Timer' information is at about the centre of the screen :o)
Mar 25, 2014 | Sony VPL-ES2 LCD Projector
I have a Sony VPL-CX61 Multimedia Projector. I just changed the lamp and I cannot get the "please replace lamp" message to go off.
When you use a projector it automatically keeps a timer of how long the lamp has been used for. The message that comes up on screen saying "please replace the lamp" comes up not because it's some how sensing that the lamp is getting old, but because the lamp hours gets to a certain number (usually up around 1500 hours). Because of this when you replace the lamp you need to reset the lamp hours counter, or the projector doesn't even know you've changed it. Every projector does it this way, and they all do it a different way, I googled the model you gave us and found this set of instructions on how to do it, so give it a go.
Reset the lamp counter hours of operation for the projector SONY VPL-CX61
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to
zero in the service menu.
Hope this worked for you,
Mar 23, 2011 | Sony VPL-CX61 LCD Projector
Comme on RESET LAMP Videoprojecteur SONY VPL EX3 procedure ?
You can reset lamp timer of VPL-EX3 by following procedure.
Connect power cord in wall socket, standby indicator will lit red.
Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER
Lamp timer will reset.
Hope this will help.
Thanks.
Mar 22, 2011 | Sony VPL-EX3 LCD Projector
I have a VPL-CX70 that has a new lamp (less than 50 hours) and the hours were reset to 0 when the new one was installed. However, today, the lamp cover LED started blinking and the projector shut itself...
The bulb is not lighting correctly.
Take out the bulb and check the connectors are not dirty and reinsert.
See if you can see the bulb looks ok, you may be unlucky that the bulb has prematurely failed (hope not)
Try again to start it.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | Sony VPL-CX70 Multimedia Projector
LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Jul 04, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Reset Lamp Hours
hi have vpl-es3 i changed the lamp but i have massege replace the lamp
May 11, 2009 | Sony VPL-CX80 Multimedia Projector
Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Feb 21, 2009 | Sony VPL CS5 Multimedia Projector
Replaced Lamp and warning is still on screen
This work´d great
the "please replace the lamp" text disappeared but the lamp timer is still on the same, but i am still satisfied that the big red text on the screen is gone :P
/Newton from Sweden
Feb 29, 2008 | Sony VPL CS5 Multimedia Projector
Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony VPL-CX70 Multimedia Projector Logo
461 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
