Question about Logitech (980240-0403) Microphone
Microphone plays my voice but doesn't record it
Hi
I got a new microphone yesterday
I set it up today
But I am having a bit of trouble with it
It is playing my voice when I plug in the microphone, but it doesn't record it
I have tried everything but I don't know what else to do
Am I doing something wrong while i'm setting it up? PLEASE HELP
  • mamaluigi Sep 19, 2008
    I used GoldWave but it didn't seem to record on any other programs too, also just now the sound on my computer is stuffed up because it doesn't play on my speakers, only through the LogiTech headset but when it plays the sound is all echoey.
  • ANURAG MUKHERJEE
    ANURAG MUKHERJEE May 11, 2010
    What program are you using to record your voice? Also the OS. Check the recording tab under sound. Check with sound recorder.
    Sergeant:
    Champion:
  • 223 Answers
I agree with anuragmi but also want to add check that mic is plugged into the input of the soundcard and if all else fails try it on someone else computer and if it works there is an issue with your soundcard or settings. Good luck.
Posted on Sep 29, 2008
How do I change a 32 Bit to a 16 Bit?
Not only does the wav have to be 16 bit, it has to be PCM, 11.025
or 22.050 kHz, 16 Bit, Mono. I think it would be easiest just to play the audio from your sound recorder right into the microphone of your computer, since the Dragon software is especially made for listening on the microphone, Or hook up the audio out from the sound recorder to the Line-In jack of your computer using a male to male phono cable.
Jul 18, 2008 | Olympus VN-3100PC Digital Voice Recorder
Tip
How to record audio on Mac OS X El Capitan
Some users of Mac OSX 10.11 probably find that recording audio is not so easy as before. Since this operating system made some changes in "Sound" preference, lots of audio recorders become malfunctional. This issue can be solved by QuickTime if you just need to record mic voice, but recording audio from sound card is another story. Soundflower is still helpful, however you may be troubled by the complicated settings. To make this stuff simpler, share you an efficient solution here.
Step 1: Open the online audio recorder, click Start Recording to activate the application.
Step 2: Follow the instruction and install a launcher, the recorder will open. You will only be asked to install the launcher when you use the app for the first time.
Step 3: Select the Audio source at the bottom of interface, it allows to record sound played on Mac, voice from microphone or both.
Step 4: You can start to record sound on El Capitan now, the sound can be streaming music, radio, voice calls or others. Click the Record button, recording will be started.
Step 5: When you want to stop, click the Record button again.
Step 6: You can access to more functions like play, rename, edit ID3 on Library interface.
Based on my experience, the application doesn't have restriction on recording time. The audio will be saved as M4A which can be played with QuickTime and iTunes.
on Apr 27, 2016 | Apple Mac OS X
I can't seem to figure out how to record anything from the the microphone or otherwise. Any suggestion or instructions?
We just got one of these today at a thrift shop. I thought it was supposed to record what you say into the microphone but it doesn't. It records your "compositions". Press "record" then play something on the keyboard. Then hit "Play" and it should play it back for you.
We can't figure out how to get the darn microphone to work. Is it supposed to work or is it just for looks?
Jul 01, 2011 | Battat B. Meowsic Kitty Kids Keyboard
Hi ! .I recorded my voice in the MSI 527. How may I play that record ? What button must I set to visualize and ear the archive. Thank you very much Marisa
To play a microphone recording file, press the Menu button once, and then push the Menu button to the right once, and now you should read the message of VOICE appearing on the Display. Press the Menu button again, and then use the Menu button to select a desired microphone recording file by pushing the Menu button to the right or to the left. Once the desired microphone recording file is selected, press the "play/pause" button to start playing the file.
this is all from the manual hope this helps
Jun 26, 2011 | MSI MEGA Stick (256 MB) MP3 Player
Have the Meowsic keyboard. Lost the instructions in the initial excitement of opening. How do you record with it? Can I get a copy of the instructions?
We can't get the microphone to work. Is there a special trick to that?
May 17, 2011 | Battat B. Meowsic Kitty Kids Keyboard
Bought the product today, installed OK but microphone not working
Go to windows Control Panel, click on Sounds and Audio Devices, and check under the "Audio" and "Voice" tabs to ensure that the recording device and the voice recording device are both set to the microphone that is associated with the webcam.
Joe
May 07, 2009 | Microsoft LifeCam VX-1000 Webcam
Logitech microphone stuffed up my Computer Speakers!
go to sound icon in bottom task bar, double click on it,go to options,then properties,then click RECORDING,make sure you have a tick in MIC,then go to back to sound icon in bottom task bar,and adjust mic settings to suit
Rod
Sep 19, 2008 | Logitech (980240-0403) Microphone
Voice tag
hi.....im andrei.your problem is very easy to solve...... try to change the microphone...^^
Jun 01, 2008 | Nokia N95 Cellular Phone
Open Questions:
See all Logitech (980240-0403) Microphone Questions
Logitech (980240-0403) Microphone Logo
402 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
