Question about Panasonic CT-27G14 27" TV
Picture goes in and out; must press/hit front bottom of tv to get picture back
I have a Panasonic CT-27G14; recently, the picture periodically goes in and out.  In order to get the picture back, I need to either press hard or hit the front bottom  of the TV, near where the front video/audio jacks are located.  I usually have to hit the tv several times before the picture comes back for good (until I shut it off again).  Is there an easy way I can fix this myself.  If not, does someone know how much it would cost to get this problem fixed? Thanks...
  • 2 more comments
  • christiejohn Sep 26, 2008
    I have the same problem.....sound but picture starts off good then when tv heats up the picture goes in and out from Black Screen to regular and sometimes rolls.
  • Anonymous Nov 09, 2008
    I HAVE THE SAME PROBLEM,AND WOULD LIKE TO HOLD ON TO THAT TV,ITS IN A CABINET AND THE BIGEST IT CAN TAKE IS ABOUT 28 INCH TELEVISION.
    I WOULD NOT MIND GETTING ANOTHER NEW 4-3 TV
    OF SOME OTHER NAME BRAND THAT FITS THAT WITH SIZE PREFEREBLY FLAT SCREEN EVEN IF ITS 26 INCH.
  • Andrew 2 Nov 09, 2008
    Ihave the same problem.The screen goes blank,but i have the audio.I turn it on and off and play with the front buttons until the picture flashes on.Iwould not mine getting a new name brand 26-27 inch Television,the same model number
    or any other good quality name T.V. especially if its flat screen.Perhaps you can fix it for a price.
  • spikeykitty Jan 27, 2009
    I have the same problem with my Toshiba, which is only about 5-6 years old. As great as it is that we all have this problem, is there an easy or cheap solution?
Universal remote code for a panasonic ct-27g14a
Two things you can do:
GOOGLE THE NUMBER OR MODEL OF THE REMOTE AND LOOK FOR THE INSTRUCTIONS FOR PROGRAMMING IT.
GOOGLE THE MODEL NUMBER ON THE REAR OF THE TV WITH THE WORD REMOTE AFTER IT FOR A DIRECT REPLACEMENT.
LET ME KNOW IF YOU NEED HELP
Mar 15, 2012 | Panasonic CT-27G14 27" TV
Panasonic CT-27G14A
Have you tryed both the front and the back inputs?
May 17, 2008 | Panasonic CT-27SL15 27" TV
27" (diagonal screen) Panasonic regular crt TV few years old, no serial # on front and too heavy for me to look at back. Picture comes on great, then a grey (NOT BLACK) screen covers 99% of screen with a...
It will be good to check the capacitor on the +B voltage that goes to the power section in the main board. A filter capacitor of about 47mF/160 V can be defective.
Next check the capacitor on the HT line to the grid-22mf/250V replace.
If possible loop on capacitors in the horizontal section particulary the IC.
Now the tip I can offer:
If the fault occurs on heating shcek out htis area to confirm and isolate the component.
But finally I understand that when you press any key the picture is good.If so check the memory IC/cmos IC in this section for logic control, it might be having a switching fault, a conflict or the video noise is coming on in default but goes off in the data selection mode. Do a soldering around this section on the IC , capacitor and see if the fault goes off or becomes irregular when this section is heated, if so there is a semiconductor producing this noise error .
So start from the begining so that we have a clean voltage inside.
I hope my advice helps.
Aug 22, 2010 | Panasonic CT-27G14 27" TV
Remote sensor on Panasonic CT-27G14 not functioning. How can I fix it?
firt try with your cellular, put your cellular in camera and put your remote control in front of your cellular and press one botton, if you see a blincking ligth, your control is good and your IR sensor in the tv is bad.
Apr 25, 2010 | Panasonic CT-27G14 27" TV
Have slide picture on top.5"after a minutes stop at 2"
check for dry electrolitic capacitors around the vertical output section
Oct 02, 2008 | Panasonic CT-27G14 27" TV
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
TV Scratch
if you mean a scratch on the picture tube, sorry the only way would be to repalce the tube.
Oct 10, 2006 | Panasonic CT-27G14 27" TV
Fuse blows.
Please check for shorted diode or condenser at power section.
May 29, 2006 | Panasonic CT-27G14 27" TV
Panasonic CT-27G14 27" TV Logo
447 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
