Question about LG Heating & Cooling
LG AIR CONDITIONER NOISE
THERE ARE A BIG NOISE IN AIR CON. WHEN THE COMPRESSOR START WORKING AND BECOME LOW AND HIGH DURING AIR CON. WORKING
  • alfaisal_200 Sep 19, 2008
    my air con. is window one
    Problem Solver:
  • 15 Answers
What kind of air conditioner is this? A window unit or a split?
Posted on Sep 19, 2008
  • TexNOz Sep 19, 2008
    It sounds like the compressor is being "flooded" with refrigerant. I know that sounds technical and it really is, but you might be able to stop if from happening. Remove the filter and give it a good cleaning. Also make sure that the metal fins behind the filter are clean and not plugged up with lint.
    If this doesn't fix the problem, then chances are it's a bent valve in the compressor and that requires a technician to properly change out.
I have a LG LP150HED-Y8 AC, A CH CODE LIGHT CAME ON HOW DO I FIX THIS?
Low pressure switch will shut down right after starting when it is low on freon. A small amount of freon will get it started but when the compressor starts it moves freon from the low line to the high
Jul 28, 2015 | LG PTAC LP150HED Thru-Wall/Window Air...
Why would the lg r410a start cooling then stop?
If its low on refrigerant, the low pressure switch will drop out the compressor. If it has an extremely dirty condensor, the high pressure switch will drop out the compressor. If it has a bad condensor fan, the high pressure switch will drop out the compressor. If the internal overload of the compressor is weak and it is marginally low on refrigerant, the compressor will stop until it cools down. The list goes on and on and on.... These are the first four most obviouse that comes to mind.
Jan 31, 2015 | LG Heating & Cooling
I HAVE A AN ISSUE WITH PORTABLE AC IT DOESN'T BLOW COOL AIR
dear sir
please make sure first your air con,s compressor is working if it, working and it,s not getting cold then it can be low gas problem or if compressor is not working then please check the thermostat settings and make tempreture correct and setting on cool mode
then i hope if it,s only normal problem then your air con will work again .
after that if not get cold then contact to air con technician for repair it (it,s need to repair and only air con special maintenance person can do it)
thank you
hope answer the question
please vote!
Sep 24, 2010 | Amcor A12000E Nanomax Portable Air...
My window air con,lg -model lwhd8008ry9, the lights are blinking what does this mean. i have ubplug it. when i turn it back on it works .
The compressor is going bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 05, 2010 | LG Heating & Cooling
Why i have high presure in the low presure side
Two common reasons for this.
1) valves weak/broken and pressure is leaking in from the high side of the system.
2) AC compressor is not running. Make sure the compressor is actually running. It has a low rumbling noise to it - and often you'll need to actually 'feel' the compressor for the vibration (of running). Or feel of the big copper line (it should be cool-cold) - or - feel the smaller of the two lines (warm to hot).
good luck
Jun 16, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Have a mistral air con, outside unit not working
there is no fuse on your condensing unit outside. pull the disconnect to kill the power to the unit and take off the removable panel above the 2 service valves. there will be an oval shaped capacitor that is marked herm and fan. there will be a rupture disc on the top that may have ruptured. also inspect the low voltage wiring(will still be hot unless you turn off the switch at your furnace). this low voltage wire operates a magnetic coil on the bottom of the contactor that closes a high voltage circuit to the fan and compressor.
Dec 14, 2009 | Heating & Cooling
LG 3phase ducted CH02 fault (internal pipe thermistor error)- every day. When it comes up the air con shuts off, and takes a few hours to clear itself. Very annoying. I notice though it comes up less if i...
have u checked your low pressure and high pressure when compressor is on. Remember the compressor has a thermal protection switch if the compressor has too much freon the A.C will work for a while turn off, then turn then off and on. Are the air filters for the evaporator clean, is the blower fan blowing the correct way. How long ago did the evaporator coil got cleaned. With a properly cleaned filter and evaporator coil you can now check for pressures. Use your ammeter and check how much the compressor is pulling and compared it to the name plate. How much tons your A.C. If you give me how much tons and low and high readings I might help you diagnose the problem. Make sure the evaporator is clean blower blowing correct way condenser cleaned and condenser fan rotating the correct way
Jul 24, 2009 | Heating & Cooling
Heating & Cooling Logo
524 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
