Question about Dell Inspiron 1501 Notebook
Vertical lines in my laptop screen
Hello! I've been using my Compaq Presario (M2223AP) Laptop for 2 years now, then all of a sudden I saw 2 vertical lines on the screen. 1 line is a clear red line (but not so thick & dark) located about 1/3 from the left of the screen while the other is a very faint (thin, almost transparent) line located about 1/5 from the right of the screen. I think it might be a monitor problem. I'm not very good in fixing computers so I have not done anything about it yet. I'd appreciate your help very much. Thanks! I can only see half my screen there is a red vertical line then it is white and then a bigger blue line and then white again how do I fix this
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
Hi mikenstacy
Try to connect a normal desktop monitor to the laptop (there will be one vga port where you can connect the monitor) and if you see those lines on external monitor as well then most probably video card has gone bad (you can try to reinstall video drivers in this case) if those lilnes are not there on external monitor then problem is with your LCD so if system is in warranty then get it replaced other wise get in touch with local compter shop and get it replaced.
let me know if this helped
Posted on Sep 19, 2008
  • 624 Answers
SOURCE: Vertical lines in my laptop screen
This appears to be a duplicate posting, see this link for the active post: http://www.fixya.com/support/t152864-vertical_lines_in_laptop_screen
Posted on Jul 22, 2007
Sorry, but I find these sites difficult to figure out - I'm not a chat room person. I just wanted to thank dg9dotorg for the comments and whenever I finally find out the cause and get it repaired next year, I will advise what caused it. edierosa
Posted on Dec 09, 2007
That a great answer I'm just trying to figure out how to fix it. I have the same problem I hooked a external monitor on it works great. How do you fix tape carrier package ( TCP)?
Posted on Feb 13, 2008
myne has a green line also but i used to be able and tap it and it would go away after i did it a few times i got it again so i tried to compress it again but it wouldnt work :P
Posted on Aug 17, 2008
mspcrepair
  • 169 Answers
I know not everyone has this ability, but if you can, go to a friend's house and hook up an external monitor to your laptop. You may need to use the function keys to switch from LCD to external, but if the lines go away on the external, you have a bad LCD. If the line shows up still on the external, then your problem is either:
a) video driver (free, easy fix)
b) bad inverter (video 'outputter') ...approximately $10-50/varies + labor costs to replace
c) bad video card/motherboard ...usually between $200-$400 + labor to replace
Hope this helps - please be sure to rate my answer :)
Posted on Sep 29, 2008
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
Mar 08, 2009 | HP Pavilion dv8000t Notebook
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
the lcd (liquid crystal display) is damaged at this time, nor the inverter, that is of course inside of your pc, im afraid you need to send this to a repair shop
cheers
Aug 12, 2008 | Dell Inspiron XPS M140 Notebook
if this line is there during boot up then it is a monitor problem usually. but if it is not then it is a problem with your windows files. you could try reinstalling your windows from the disks you were given with it? otherwise i will look into it. email me if you need more help. milliprowd21@yahoo.co.uk
thanks
matt
Jul 30, 2008 | Acer TravelMate 2300 Notebook
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
May 04, 2008 | Dell Inspiron 6400 Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
you could try and download a new display driver from here http://h10025.www1.hp.com/ewfrf/wc/product?cc=mx&lc=en&dlc=es&product=499234 if that dosent help Id imagine it is the screen that is at fault.
Jun 09, 2007 | Compaq Presario Laptop
Dell Inspiron 1501 Notebook Logo
425 people viewed this question
Alun Cox
