Question about Whirlpool Washing Machines
LBR4132HQ0. There is auto on/off switch that is mounted on the upper/right side of the drum. When the lid opens the switch is turned off and the drum stops spinning, and vice versa. It's broken and I need to find a part. But I don't know what the thing is called and can't find it on the net. Is it something I can do myself? Also, how do you get the top off the machine so that I can replace the part? Thanks!
SOURCE: replacing lid switch on Kenmore 80 series washing machine
It's attached under the top panel but depending on the year of manufacture it could be on the right, below a hole where the strike comes down or on the left rear under the console.
Posted on Jan 07, 2008
  • 59 Answers
SOURCE: replacing lid switch on Kenmore Model#11022622100 top loader
THERE IS TWO SCREWS IN THE REAR OF THE TOP YOU HAVE IN THE PICTURE HERE REMOVE THOSE TWO SCREWS PULL CONTROL PANEL TOWARDS YOU AND PULL UP THERE ARE TWO METAL STRAPS ON EACH SIDE TAKE A SCREWDRIVER AND POP THESE OUT THERE IS A PLUG FOR THE LID SWITCH BEHIND THE CONTROL PANEL UNPLUG IT NOW PULL THE CABINET TOWARDS YOU AND IT WILL COME OFF! FLIP THE CABINET OVER AND YOU WILL FIND THE LID SWITCH
Posted on Apr 29, 2009
jmgldsmth
  • 2005 Answers
SOURCE: replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
Posted on May 29, 2009
erpaalai
  • 999 Answers
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Posted on Aug 10, 2009
SOURCE: Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Posted on Oct 09, 2009
Kenmore 12502100 won't cmplete rinse cycle
This is a typical symptom of a lid switch problem. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (Part number 3949238).
Mar 21, 2010 | Kenmore 23822 Top Load Washer
Error: open upper cover exit jam
Feed Jam or Exit Jam ecblank.gif ecblank.gif dot.gif ecblank.gif 1. Remove the tray and clear any misfed sheets as given above.
2. Open the top cover.
WARNING! The fuser area will be hot. This area is clearly marked. Do not touch it.
CAUTION! Never expose the image drum unit to light for more than 5 minutes. Never expose the image drum unit to direct sunlight. Always hold the image drum unit by the ends or from the top. Never touch the surface of the green drum inside the image drum unit.
3. Carefully lift out the image drum, complete with the toner cartridge. Be careful not to touch or scratch the green drum surface.
4. Remove any jammed sheets from the paper path.
5. Re-install the image drum complete with toner cartridge, ensuring that it correctly locates into the slots on each side of the printer.
6. Close the top cover and press down to latch it closed.
7. The printer will warm up and commence printing when ready. he page lost through the jam will normally be reprinted.
NOTE If the edge of the jammed paper protrudes (or can be seen) from the exit, reinstall the image drum, close the top cover and switch the printer on. Remove the jammed paper from the exit when the exit roller begins rotating after a few seconds after switching on. However, if the jammed paper cannot be removed, contact a service representative.
Mar 12, 2010 | OKI B4350 Laser Printer
Before the machine gets to the rinse cycle it shuts off with the drum full of water. I can turn the dial back or forward to rinse and it will ossolate again for a few minutes and then stop, but the water...
If this is a Kenmore top loader, the most common cause of the symptoms you describe is a lid switch malfunction. Symptoms include, filling and stopping on the intial fill cycle, stopping after the wash cycle, failing to advance to the rinse cycle and no draining.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between sites so shop and compare.
If you have questions, need additional assistance, please post back with your model number (located on a nameplate along the wash tub opening under the washer lid), so I can provide you with better assistance. I hope this helps you.
Feb 11, 2010 | Kenmore 22422 Top Load Washer
Water is now filling, washing going round in drum but not rinsing or spinning.
Spinning and Rinsing require a safety switch to be enabled by the closing of the washers lid.
Check around your lid and washer lid opening to find the mechanism that is used to activate the safety switch mounted just under the lid opening inside your machine. Sometimes it is a plastic plunger(protrusion) on the lid that mates with and opening(hole) in the machine around the lid opening to cause this switch to close. Other times it is on the hinge side of the
lid and the protrusion is formed right into the metal of the lid itself to push a plunger on the hinge side to close this safety switch.
Most spinning problems on machines are cause by this lid safety switch. Washing machines cannot spin if the lid is not closed and this safety switch is not working to switch power to the spinning motor.
Aug 30, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
20852 stops at end of wash cycle - won't start again until we pound in upper right hand corner of lid.
I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of a replacement is $25 to $35.
NOTE: Pounding on the lid or storing heavy items on the lid can contribute to premature failure of the lid switch.
If you have questions, please let me know. I hope this helps you.
Aug 21, 2009 | Washing Machines
Drum won't spin
check the lid switch plastic tongue mounted some times front--,,lid right hand side,this is a safety measure switch,when lid is open it disables the spin cycle-------tom
Aug 22, 2008 | Kenmore 25842 Top Load Washer
My kenmore 80 series (top load) washing machine fills up with water but won't spin nor agitate.
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
This is a simple and inexpensive repair. I hope this helps you. Let me know if you require further assistance.
Aug 13, 2008 | Kenmore Washing Machines
Kenmore top load 2 heavty duty 2 speed
This is usually a symptom of a defective lid switch. The link below will explain how to access it. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
I hope this helps you. If you have questions, please let me know.
Aug 09, 2008 | Kenmore 24032\24036 Top Load Washer
Spin cycle
Check your lid switch. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
This is a simple and inexpensive repair if you do it yourself. I hope this helps you. Let me know if you require further assistance.
Aug 08, 2008 | Kenmore 24032\24036 Top Load Washer
How to fix the lid sensor switch?
If you still require assistance, follow these instructions. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
I hope this helps you. If you require assistance in locating parts, or need further advice, please let me know.
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
50 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
