Question about Alpine IVA-D310 Car DVD Player
Want to watch dvd without being parked
Ive read on here to hook up the yellow and blue wire(parking brake lead) to red ing. pwr. what about the yellow,black wire to the brake pedal?
    Problem Solver:
  • 7 Answers
The easiest way to do this is buy a PAC-7 to wire in onto your brain. This item costs $20 bucks off of ebay. If you dont want to spend that you could get a toggle switch and wire that in because in order to get that to work you have to switch the toggle 3 time to get this to work. The Pac does the switching ineternally giving you a seamless view.
Posted on Sep 23, 2008
Pionner avh-x2550bt wiering diagram
Red=ignition
Yellow=memory or constant power
Orange=illumination
Black=ground
Blue/blue w/white=Amp remote
Speakers are white/white w/stripe= front left
grey/grey w/stripe =front right
purple/purple w/stripe rear left
Green/green w/stripe rear right
If its a dvd player one wire will be for brake "ground" (have to be in park in order to watch movie unless bypassed)
Jul 11, 2016 | Car Audio & Video
My vm9510 wont play the dvd with out saying parking and screen blue
You have to connect the park wire of the Jensen to your hand brakes that gets a negative signal everytime you engage it or you can try to put in series the park wire to a switch and any ground. Then read your manual how many times you got to switch it on and off until the picture appears when your dvd is playing. Same thing if you connect it to your parking brakes you got to engage your parking brakes on for 1 or 2 secs then back off then back on again for 1 or 2 secs keep doing this varying the secs till you get a picture. That will be the sequence to turn off that blue screen and on the dvd to watch the movie. Read your manual very carefully it will tell you the same thing but you definitely have to hook up the brake wire or else you will never see the picture. Check the manual for the color of the brake wire or just find the longest wire on the harness and thats usually the brake wire.
Apr 07, 2010 | Jensen VM9510 Car DVD Player
How to install a iva-d310 from alpine
The yellow/black wire is for the foot brake and the yellow/blue is for the parking break. These wires need to be hooked up in line with the pinch connectors to the correct wire. The yellow/black wire needs to hook up to the wire to the foot break lead wire before the switch and the yellow/blue needs to hook up to the lead wire before the parking brake switch. This is a sefty feature to deactivate the video display because it is illegal to have video in the view of the driver while the vehicle is moving. These wires are used to tell if the car is stopped.
Dec 06, 2009 | Alpine IVA-D310 Car DVD Player
I have a alpine cva1003 and cant get the screen off safety mode to play the dvd's. I have the parking break wire from the radio, which is yellow and white connected to the single parking break wire. is...
In order for the video to work you need to hook up both the parking and the foot brake leads so you would have to press in the foot brake pull the ebrake let up on the foot brake then the video should come up but if u want to watch videos all the time moving or stopped youll need to do some custom work so:
Short of making a microprocessor to do the sequence the easiest way is the two switch method. just mount two switches together and do the sequence.
Although the idea of only one switch and the foot brake hooked up correctly might work too.
The best way to go about it is to hook up the system as is should be and use a voltmeter to see what voltage changes are on the lines. Then hook up the switches accordingly.
hope that helps!!
Jul 16, 2009 | Alpine CVA-1003 Car Video Player
Dvd player not working
you just need to hook up the foot brake wire (yellow and black) and hook up the parking brake wire (yellow and blue (looks green) ) set the parking brake then press and release the foot brake and your dvd picture will play
Mar 12, 2009 | Alpine IVA-D300 Car DVD Player
Bypass parking brake for dvd player Kenwood kvt 512
Just connect the purple safety wire to the car's ground location or to the other ground wires.
Dec 25, 2008 | Kenwood KVT-512 Car DVD Player
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
BYPASS
The security device was created to avoid you from watching DVD's while driving. It is simple to bypass. Simply take the parking brake wire (blue/yellow stripe wire) and connect it to the a ground wire (all black wire). This will trick the DVD player into thinking that the car is in park with the parking brake on at all times.
Apr 03, 2008 | Panasonic CQ-VD7001U Car DVD Player
Parking brake
Parking Brake Lead (Yellow/Blue) Connect this lead to the power supply side of the parking brake switch to transmit the parking brake status signals to the IVA-D310.
Mar 04, 2008 | Alpine IVA-D310 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
you need 2 toggle switches . yello/blue wire to switch - switch to ground.
yellow/black wire to switch- switch to red ing. wire. turn this switch on and pulse the other(yellow,blue) 3 times and leave on, then turn the other switch off and then you can ride and watch dvd. just did it this morn. QTRHRS
Feb 24, 2008 | Alpine IVA-D310 Car DVD Player
Alpine IVA-D310 Car DVD Player Logo
76 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
