Philips DVD recorder, (250gb) DVDR3460H. can not remove disk .........
I can not eject the disc from my Philips dvdrecorder (250gb - DVDR3460H) - when the player is powered up & turned on - it automatically starts scannin the disc thats in the drive and i can not prevent it, interrupt it or do anything with it. spinning disc appears in the corner of the screen saying loadin - which lasts about 2 hours, even tho it will not play disk . machine freezes etc - i contacted philips - they advised me to download the updated software - which is all well and good and i did do that.. only problem being - I NEED TO SOLVE THE PROBLEM FIRST AND GET THE STUCK DISC OUT OF MACHINE, BEFORE I CAN LOAD THE DISC WITH UPDATE ON !!!.
thank you philips - you were a great help!..
please help i am stuck stuck stuck
yours frustrated
debij75
  • debij75 Sep 20, 2008
    thank you for the advice that i need to open up the player to release the disk from the inside - but as i've never done anything like this before, i feel i need more detailed instructions on how to do this safely,without causing further damage..
    Sergeant:
  • 399 Answers
You just need a proper screw driver to open the dvd and remove the stuck cd from the device.
1Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
Step2Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place. Step3Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases. Step4Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet. Step5Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center. Step6Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc. feel free for further queries. thanks.
Posted on Sep 20, 2008
  • 19,396 Answers
First unplug power cord for two minutes.
Then restart the machine, and keep pressing eject button repeatedly, while the unit is restarting. Do this several times until it ejects before starting to read.
If it does not eject restart the DVD and try again.
If that does not work, then you will need to open the DVD, as already suggested.
Give it a try , 9 on ten it works after a while.
    Master:
  • 763 Answers
Try this unplug it from the circuit. open the top cover of your dvd. then plug it again after that try to push several times the button open/eject. so that you can see whats happening inside and what cause the stuck cd. if still doesnt work then try to move gently the cd to come off but very careful about this or try something like lifting some parts of the disc tray inside to be able to come off or open by itself im always doing this procedure when a disc stuck on the player. do it at your own risk and be careful. hope that helps!
CHARCOIS
    Master:
  • 726 Answers
Your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
Posted on Sep 19, 2008
U99 error code
The remote isnot going to eject the the disc, You have to press the eject button on the unit, To get the disc to eject,
Nov 26, 2012 | Panasonic Dmr-eh67e Pal Dvd Recorder With...
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I have several older dvds recorders which use 4x
Do you have any "£1" shops in your area, "Pound World", "Pound Empire",etc. We have 3 here. All have old 4x DVDrecordable disks.
Mar 09, 2009 | Emerson EWC1903 19 in. TV/VCR Combo
Philips dvdr3430v dvdrecorder/vcr combo -hacked into to make multi regional 2yrs ago now buttons on machine not responding to touch only works with the remote, therefore cannot open disc tray. please help
Keep pushing the "STOP" button on the Remote-controller will open the tray. This works mostly on all Philips DVD's. I tried on my recorder, it works.
Have fun!
Mar 07, 2009 | Philips DVDR3430V DVD Recorder/VCR
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
U88
the dvd disc you are using is copyright you cant copy the disc.. "the disc is encrypted'
Feb 07, 2008 | Panasonic DMRES15 DVD Recorder
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Oct 15, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Televison & Video Logo
356 people viewed this question
Top Televison & Video Experts
