Question about iLO 3200 32 in. LCD Television
Ilo 32hd tv from InitialTech
I have the same problem with the ilo hd tv as most everyone else, it willl not change channels or volume. I replaced the control board, and still have the same problem. Do you have any Idea what I should try next? Is there a way to test if the board I bought was good?
  • jspfunk Sep 19, 2008
    the board seems to be working. WEhen I turn on the TV I have to press one of the buttons to more the TV off standby. The Sensor for the remote is not work either. Is the a board that controls both I should look at.
  • 4 Answers
I own an ILO TV that is still under the extended warranty. I've had it repaired twice since May 08 and it has failed again. Since it is still under warranty, I will send it back in to be repaired.... again. If I were you, I'd cut my losses and buy a new TV from any store except Walmart.
Posted on Sep 27, 2008
I have an ILO 32HD and the HDMI input does not seem to work.. goes from no signal to HDMI 10801 but i get a flash of a picture somtimes.. My first HD and can't see it!!! I have tried 2 NEW HDMI cables...
HDMI issues are almost always the scource and not the TV. If HDMI fails to work then use the component inputs as your picture will still be in high definition when on HD channels..
Nov 11, 2009 | Televison & Video
Cracked lcd trying to buy a ilo-32 hd lcd
You do know that the LCD display will be a few dollars short of a new set ? If your still interested in it then let me know.
May 20, 2009 | iLO 3200 32 in. LCD Television
Ilo 32HD NO Channels! buzzing noise
the input setting may need changed on your tv
Dec 09, 2008 | iLO 3200 32 in. LCD Television
Ilotv 32HD
The only way that I know of to eliminate this problem is to buy a new TV. My ILO TV has been repaired twice since May 08 and it went out again for the third time. The problem starts out as an intermittent problem.... You turn the TV on, the audio is fine but there's no picture, you will be unable to change the channel or volume whether you're using the remote control or the buttons on the TV.
This TV should have been recalled. Don't throw good money after bad and don't reward the manufacturer and retailer for their bad behavior, buy your next TV from a different retailer.
Sep 17, 2008 | iLO 3200 32 in. LCD Television
Ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Aug 16, 2008 | iLO V27DMBX Television
Ilo-32HD
Check the menu to make sure it is not in a lock mode. If that is OK, it probably needs a control board. On some brands that might be called a digital or tuner board.
Jan 22, 2008 | iLO 3200 32 in. LCD Television
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
Initial hdtv-322
This tv is basically the same as the ILO 32HD. Look for posts on this model and you will understand that these tv's are "disposable" and the manufacturer will not stand behind them.
Dec 13, 2007 | Initial HDTV-322 32 in. LCD Television
Cannot change channels
Hi! I have been through this situation on a 26" model of ILO LCD TV. I think the problem you have is the same, but could you clarify one thing for me? Is your model an ILO-3200, or is it an ILO-32HD? I suspect 32HD, because I know the problem exists on the 26HD models which are basically very similar in design and say manufactured by Initial Technologies on the back of the set. Does your unit list this manufacturer on the back? Let me know. Thanks!
Sep 30, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
148 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
