Question about RCA HD52W59 HDTV Projection Television
Please help me
RCA hd52w59 i looked ath the fuses but dont know how to fix them. the red green and blue colors are showing up and hour glass screen
  • Barry Solomon Sep 24, 2008
    Where can the fuse be bought?
    Genius:
  • 1,030 Answers
Hello i just posted detailed instuction on the fl231 problem. scroll down to the tips for the hd52w59 or in my profile under tips. if u need any extra help just let me know
Posted on Sep 21, 2008
I have a RCA Hd52w59 television that has a blurry red green blue colors on screen and the pics looked like they are caved in .any help ?
RED BLUE and Green are the component colors. If you are using component cables, which most likely you are, check to see if the Green has come unplugged. Try switching the cabls to a different input. Actually, if you get the same problem on another input that say....your DVD player is hooked to, you have a bad tv. If not, try to isolate it to the simplest thing first e.g. cables, input source, etc. Please don't forget to rate this solution for me.
Jan 21, 2011 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
I have a HDTV 524159 RCA, it has an hour-glass effect on both directions. On the left side, it hour-glass inward with red and yellow stripes and on right side blue and light blue stripes. It hour-glass...
Hi Sandy, the problem with your TV is called "convergence". It can be a problem with the convergence board or more likely in this model in the power supply or deflection circuits. Unfortunately, troubleshooting by a technician is required.
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA D52W19 52" Rear Projection Television
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
