Question about Sylvania 6620LDG 20 in. EDTV-Ready LCD TV/DVD Combo
Sylvania ssl2006 do I need something behind the tv so I can mount the tv to the wall?
shaggyrat
  • 1224 Answers
SOURCE: remove tv from wall mount
there is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
Posted on May 26, 2008
  • 11 Answers
SOURCE: removing stand to mount on wall
Just called the company and was told that you simply remove the 4 screws on the back of the stand that is holding it to the tv....They do NOT recommend mounting the TV because it will make your warranty ineffective-per the rep.
Posted on Jul 31, 2008
SOURCE: sylvania SSL2006 lcd tv
Did anyone figure out a solution or did you get rid of the TV?
Posted on Oct 03, 2008
SOURCE: ssl2006 sylvania TV goes dim and turns off within 5 seconds when turned on
There is no audio out, to hook up surround sound. Does anyone know how to deal with this problem?
Posted on Oct 24, 2008
  • 125 Answers
SOURCE: need to take a flat panel tv off the wall mount
Here are a few spots you can try. Underneath, there might be locks that use alan keys. You might need a long alan key depending on how big your TV is. Unscrew these alan keys as much as possible. Some mounts require up to pull the bottom of the TV out and then lift straight up. Try using a flashlight and look all around the TV, Also check the top. Some have clips that need to be pushed to the side. These clips have holes in them and sometime held in with zip ties to keep them locking the TV, You will need to cut the zip ties. Hope this helps...
Posted on Mar 15, 2009
Can i wall mount my 32" LC320SS8 sylvania tv by the 4 screw holes in the back of tv
Yes, with a mounting kit. A plate screws to the TV using those holes, then attaches to another plate that's attached to the wall.
Jul 06, 2011 | Sylvania LC320SS8 32 in. LCD Television
How do you Wall mount a Sylvania LC370SS9 TV
If you have a wall mount kit, it is fairly simple. You just find the place that you want the tv to go and find a nearby stud to install the mount. After that you will want a second person to help with either holding the tv up or screwing in the tv to the mount. There are four screw holes in the back of the tv to screw through the wall mount plate into the back of the tv. Check to make sure it is stable, then you have successfully installed the tv to your wall
Jun 17, 2011 | Sylvania LC370SS9 LCD TV
Model SSL2006 will not accept TV (cable) channels above 13.
You must be sure you are in connection with the menu. Read the menu and find [video source] antenna/cable. Be sure you are in "cable" source. And then program your TV for channel search! Try this, and thanks for asking!
Oct 06, 2010 | Sylvania Televison & Video
Best wall mount for sylvania 6842thg plasma
To make it simple: Mounts go by the size of the TV.
You have the choice to get a standard mount that can only swing or a mount that can swing and tilt or even extend. Plasma TVs are a bit heavier, than LCDs therefore, you need a solid mount. There are wall mounts and ceiling mounts. Mounts can be purchased from Home Depot, Lowe's and best buy, they can also be bought on line. If you buy it from a local store and does not fit, you can take it back the next day, an option you wont have if you buy online.
Good luck
N Sabre
Nov 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Cannot figure out how to remove stand so I can mount TV on wall
did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
amsaxo@yahoo.com
Dec 02, 2008 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Sylvania SSL2006 lcd tv
Feb 19, 2008 | Televison & Video
Dead t v
Good Luck! My SSL2006 tv would cuts off when turned on. Under warranty, the local auth. repair shop tried unsuccessfully to replace parts to fix it. In addition, the repair shop told me it was difficult getting thru to parts support. Either the wrong parts were sent, the right part didn?t work, or additional authorization was required to repair TV. On many occasions I made calls to Sylvania, on the repair shops urging, to find out the status on its repair parts to help get the right parts sent. The set was in an auth repair shop from Feb.-Aug. The shop couldn't fix it. It was sent to Sylvania's repair center in CA, August 18th. WHEN WILL I GET MY TV BACK? I want a new TV!! I have been without this TV for over 6 mos.! I'm very upset with customer service and its repair centers and will never buy nor will I recommend purchasing a Sylvania product.
Sep 02, 2007 | Televison & Video
Sylvania 6620LDG 20 in. EDTV-Ready LCD TV/DVD Combo Logo
243 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
