RCA TV wat are tact switchs?
  • 790 Answers
Hi
the tact switch!? that is the swhitsh in front panel of the TV. like the volume button, channel button. that is the tact switch.
Thanks!
Posted on Sep 19, 2008
Rca 27f520t tv turns off by its self
This is a common problem with these TV's caused by the buttons at the front. Free fix 1 which can work - press the buttons heaps of times quite hard.Free fix 2 - remove the buttons altogether and use your remote.More expensive fix - Replace the switches, they are called tact switches:MCM part # 28-10720 - http://www.mcmelectronics.com/
Try the above in the above order. Hope this helps!
Nov 21, 2011 | RCA TruFlat 27F520T 27" TV
RCA P52921 changed channels by itself and unplugged it to reset it and
Take batteries off the remote and check if it is the remote , otherwise it is a stuck key on the tv or the control board is gone,
regaards
Mar 31, 2008 | RCA P52921 52" Rear Projection Television
Menu screen, volume, and chanels changing on own. Removed batteries from remote and problem contiues. Is it the board behide tv controles?
most likely especially if it is revealed that some liquid has spilled and got into the tact switches, only cure is replace the tact switches
try this first - locate the IR sensor on the TV and cover it with the fleshy palm of your hand -if the problems stops then the IR sensor could be picking up IR interference from CCFL lamps etc.
Aug 10, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L26WD26D LCD TV:Turn on,turns itself off,then on,then off, then on, then off.
it will either be a defective tact switch on the control buttons on the set
or a main board causing this problem it it still has warranty you would contact RCA and get the number of a local servicer to assist you with this problem
Nov 09, 2009 | RCA L26WD26D 26 in. LCD TV
RCA Truflat 20F512T turns itself off and on
If it is an intermittent problem, changing the tact switches on the main board solves a lot of these problems. Tact switches are on front of main chassis where customer controls activate them.
Oct 24, 2009 | RCA Televison & Video
Have problem with the volume in my rca tv
stuck tact switch is most likely the cause or the become leaky and conduct we change a great amount of them on those sets
Oct 23, 2009 | RCA F32650 32" TV
RCA 32" TV went off suddenly and won't come back on
Replace operator/control panel, or clean the board and replace all the switches on it. The tact switches get flakey and cause a multitude of problems.
Techman54
Jul 13, 2008 | RCA 32V420T 32" TV
RCA 32" TV
The most likely problem is a stuck tact switch, if it goes up in channel number, 5, 6, 7, etc. then the channel up button is stuck, if it counts down it`s obviously the ch. down button. Problem is you have to remove the guts of the set to get at the control boards screws, you can try turning on the set and poke around the offending push button with a tooth-pick, if it stops changing channels leave it alone and use your remote from now on to change channels, if you can`t get it to stop the tact switches or the control board module will have to be swapped out, hope this helps
Nov 27, 2007 | RCA F32695BC 32" TV
RCA 27V412T
ok! change all tact switches! your tact switch has abnormal resistance! thats why your tv is changing system!
Oct 01, 2007 | RCA F27669 TV
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
