Question about Lands Phones
Hi , my new Uniden phone will not record messages . I have followed the steps in the "common issues" section but it still wont record. Cheers
I dont no how it did it , but the following day it was working fine.
Cheers
Posted on Sep 19, 2008
How do I change the message on my answering machine?
Which Uniden phone do you have? for some models, you access the Answering System menu from the base; on others, you need to be holding the handset. The generic steps are below.
On the appropriate part of the unit, make sure that the phone system is in standby (no active calls on any handset). Then press Menu. Use the arrow keys to find the line for Answering System. Press OK. Navigate to a line about Greeting and press OK. You should see (and select a line) for Recording message. You'll be prompted to ensure that you want to record a new message. If you are using the handset, hold the unit about 6" away from your head. After confirming that you wish to record a new message, speak your new message clearly. When you are done, press End. The unit will cut off the recording if your message was too long. Make sure to save the message. Then go back up in the Menu system and look for a line for "Play back Greeting". If the message isn't clear, start over.
I hope this helps. Please add a comment with the model number of the phone for specifics for your manual. Some DECT phone manuals are available here: http://www.uniden.com.au/australia/cs_operating_manuals_phones.asp .
Nov 21, 2015 | Uniden DECT 6.0 Cordless Phone
How do i change answering message on Uniden 5.8
To configure your answering , press menu botton while your phone is on std-by mode then scroll down using the down arrow, then select each choice to configure number of rings-mode-and for the message , just follow the voice prompt to record it.
Jul 14, 2014 | Uniden DECT 6.0 Cordless Phone ID
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
I need to record a message for my uniden dect 6.0 and dont have the manual can you give me directions
Push mail button lower right, then on large round button under screen right click till you see Rec new message #8 and record greeting and follow instructions
Sep 20, 2011 | Uniden Lands Phones
I want to change my answering machine greeting
For the DECT2180, press Mesage/Mute on any handset to access the answering system. Wait for the announcements to be finished or press 5 to skip. Then press 8. Wait for the message "record greeting" then begin speaking. Press 8 to stop recording. The system will play back the greeting. Press End to save the greeting and exit the system.
For the DECT2080, press and hold Greet on the base. When you hear "record greeting", start speaking your message. Press Greet again or the play/stop button to stop recording your message. Press Greet again to play back the current outgoing message.
Which Uniden do you have? There are several models. Manuals for all of the current ones are here: http://www.uniden.com/index/manuals_results.cfm?cat=59 .
Most models will be similar. Setting a new message when you call into the system is a totally different issue and not all Uniden phones support the feature. Read your manual.
I hope this helps.
Jan 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
The LED "new message" indicator on the upper
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Nov 10, 2010 | Uniden DECT 6.0 Cordless Phone ID
How to erase current greeting and record a new one,the model number on my phone is 27851GE1-B
The detailed instructions for recording a greeting message is given in the instruction manual which can be downloaded from here:
http://www.home-electronics.net/ge/pc/IB/27851GE1_IB.pdf
The instructions are given under "Recording the Outgoing Announcement" section.
Hope this solves your problem. Thanks for using FixYa.
Oct 04, 2010 | Uniden Cordless Phone
My Uniden corless phone answering machine has "lost" my message and substituted a "robot" Male voice instead. Can you direct me step by step how to reset my machine Model DECT 6.0? I don't have the manual....
With out the specific model (DECT 6.0 is a platform that all manufacturers use, it does not denote a specific model)
it is hard to say. It sounds like you have either deleted your custome message, or switched it to the pre-recorded announcement.
You can go here to download the owners manual for your phone and follow the steps for re-recording your announcement, or turning it back on if that is all you need to do.
Jan 17, 2010 | Uniden Cordless Phone
Record new incoming voice message
http://www.uniden.com/pdf/EXAI4248om.pdf
Jan 27, 2009 | Uniden Cordless Phone
Lands Phones Logo
51 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
