Question about Epson Stylus CX6000 All-In-One InkJet Printer
E-90 error on my printer - Epson Stylus CX6000 All-In-One InkJet Printer
    Sergeant:
  • 352 Answers
Hi stev, I would suggest you update your printer drivers, try this, it should help:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Error code f-01
F10 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems
Feb 22, 2013 | Office Equipment & Supplies
My MP-90 flashes "E O"
get series MP258 printer. According to my experience of Error P10 can be solved by replacing one or more of the following ...
Aug 16, 2011 | Office Equipment & Supplies
I was printing a paper and all of a sudden thing thing came up it said contact epson E-90 how do i resolve my problem
An e-90 error is a fatal error with the printer itself, the only solution is to contact Epson if the unit is still under warranty. Otherwise I understand the fix is more cosstly than the printer. The error seems to be reported most when a new black cart. is installed, you could try reseating the cart, powering down the unit for 15 min and then plugging back in and see if that will reset the printer. You can also try the SCC reset utility....http://www.ssclg.com/download/sscserve.exe
Mar 08, 2011 | Epson Stylus CX6000 All-In-One InkJet...
Error 90 call for help
Your printer needs the attention of a service technician. Before then, you may try reinstalling your operating system or the printer driver or both.
Jun 18, 2009 | Epson Stylus CX7800 All-In-One InkJet...
I have error code e 90 on my epsom printer
Generally the fix for most "e 90" error messages on Epson printers is to check under the hood of the printer for something that is there and shouldn't be, eg. glue stick, pencil, paper jam, etc. Most e 90 error messages are solved by simply removing something that shouldn't be there. If, in fact, that doesn't fix it, you should try removing the printer catridges and re-setting the printer. If this still does not fix the problem you should try contacting the Epson Customer Service department and try and get a replacement printer, considering this is surely a hardware issue.
May 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Error E-90
error E-90 means that something is stopping the ink carriage from moving its full extent. Open the scanner and check that the ink carriage lid is firmly locked down, check along the path of the carriage for any foreign/loose objects. Use an alcohol wipe or similar & gently wipe the plastic registration strip that goes through the top rear of the ink carriage. Be careful not to dislodge or damage it. If the carriage moves when you switch it on, pull out the power cable when it is across to the left and check for loose gears or foreign objects in the gears on R/H side. Hope this helps.
Apr 20, 2009 | Epson STYLUS CX5900 Printer
Error code E-90
When turning on the power, the Carriage
Unit collides to the Change Lever
located to the front side of the printer. CAUSE
PF Motor
Ink System
CR Scale
CR Encoder Board
Holder Shaft Unit
OR IT S SAMPLE JUST WHEN YOU OPEN THE SCANNER TRY TO MOVE THE CARRIAGE BY THE GEAR OR SOME PAPER JAME IT DO THIS PROBLEM.
Oct 22, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson Stylus CX7800
Hi-
E-90 error is a carriage error. You can reset printer by turning it off and unplugging it then check inside the printer after opening the top cover, check for any parts that are damage or any foreign objects inside.
Then replug and turn it on, if all fails then chances are the product is damage or broke. call epson if you still have a warranty for replacement or have it service.
Thanks for using Epson
Sep 11, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
327 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
