Question about Mitsubishi VS-55609 55" Rear Projection Television
How do i program my mitsubishi remote
I bought a 55" rear projection tv from a buddy wuth a remote and its the universal remote that comes with it. The problem is that he didnt have the owners manuel and dont remeber how to program it to like my vcr dvd player and things like that and I was hoping sombody could help me out by explaining how I can program it to my dvd player and vcr and surround sound so that i can have it all on this remote. Thanks Corey
techman
  • 3130 Answers
SOURCE: Mitsubishi Rear Projection TV
Easy! But you will need the original remote. On the remote is a button called QV for quick veiw. Press that button at the same time with the 9 button. This will open the lock, But it will return when you turn off the set and turn back on again. If you want it to do a normal turn on , once you open the lock you must go into the menu and remove the lock from the set completely. You may be able to find a friend or a store that might let you borrow an original remote? Sorry to be the bearer of poor news my friend. Good Luck
Posted on Aug 14, 2006
premtech
  • 934 Answers
SOURCE: Mitsubishi WS-65611
Just from what you've described it could be any number of things. One of the more common problems is the convergence Ic8c00 Stk393-110 Mits. Part # 267p155010 and the fuse 9a04... On a scale of 1 to 10 and 10 being the most difficult the task is about an 8 to replace and trace test the convergence circuit. You can however check and see if 9a04 is open, and if so, then you know where the problem is and can be more informed when asking a shop about what they charge to repair this problem. Take a VU or DMM meter set on continuity and loacte 9a04. That location number will be printed on the board right next to the component you're looking for... Next test it for continuity. If you get no reading it's open and the convergence amp is the culprit. Hope this helps. Bill
Posted on Jun 06, 2007
  • 1153 Answers
SOURCE: PROBLEM WITH MITSUBISHI WS 55411
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Posted on Sep 06, 2007
premtech
  • 934 Answers
SOURCE: mitsubishi 55'' rear projection 1080i hd tv lense cleaning
Pry off the lower speaker grill... Remove the screws at the lower edge of the screen framing and lift screen frame of the two catches at the top. Be careful, there will be wires still attached to the front button panel... Then lay the screen down and support the bottom of it in some way because the button panel wires won't reach all the way... then using windex and papertowel cleam the mirror and lens(s) on each of the crts. Also clean the back or inside of the screen area and reverse the process to re-mount the screen.
Bill
Posted on Dec 19, 2007
MrBob84
  • 90 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Posted on Feb 13, 2008
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
Tv remote codes free
IF YOU DONT HAVE THE MANUAL, LOCATE THE MANUFACTURERS NAME AND FIND THEIR INFO ONLINE AND CONTACT THEM FOR THE CODES FOR YOUR MITSUBISHI
Feb 03, 2014 | Mitsubishi WS-48311 48" Rear Projection...
Tv tuner dk whats going on?
Yes, you can play DVD movies on TV, you need the tuner if you want to see broadcasted channels.Your universal remote should have codes for Mitsubishi Rear Proj. Tv's. If you dont have the instructions with the remote , call the manuf. Good luck!
Nov 13, 2013 | Mitsubishi VS-50609 50" Rear Projection...
How to turn on tv
Hello, try holding the power button for 5 seconds and see if it will come on, otherwise try a universal remote programmed to a mitsubishi tv. If it still won't come on it might have a problem in the power supply....tks
Nov 08, 2013 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi tv ws65613 and remote wont work
You could try a replacement remote from www.Remotes.com
You will need an original or the replacement to access some of the features of your television
I hope that this helps.
asnowman
Oct 12, 2009 | Mitsubishi WS-65613 65" Rear Projection...
WS-55809 with Universal Remote
you will have to get a new mitsu remote in order to make the adjustment. Most universal remotes are made to just do basic functions, unless you start getting into nice sony touchscreen remotes but then they cost 100 by themselves.
the remote to a mitsubishi wd55513, wd65513 etc will also work on this set, I have done it before.
Here is one on ebay:
http://cgi.ebay.com/MITSUBISHI-TV-BIG-SCREEN-REMOTE-ORIGINAL_W0QQitemZ190275200565QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item190275200565&_trksid=p3286.c0.m14&_trkparms=72:1234|66:2|65:12|39:1|240:1318|301:0|293:1|294:50
Dec 21, 2008 | Mitsubishi WS-55809 55" Rear Projection...
50604 tv is trying to program channels how do i stop it ?
have a look here for your replacement mitsubishi remote:
http://www.electronicadventure.us/mitsubishi.htm
regards
Nov 26, 2008 | Mitsubishi VS-50604 50" Rear Projection...
Cannot program my tv remote to my dvd player
If you bought an Off brand DVD, the code my not be stored in the eprom of the remote.....Call Mitsubishi to be sure.
Jan 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
See all Mitsubishi VS-55609 55" Rear Projection Television Questions
Mitsubishi VS-55609 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
