Question about Dell Dimension 3000 PC Desktop
Installed new hard drive now will not boot
I installed a new WD EIDE hard drive following the instructions. Put in the XP cd, restarted the pc and keep getting "strike F1 to retry boot, F2 for setup utility" Called WD support and after a 1/2 hour of waiting on hold no one there could figure it out. They said call Dell......Any ideas?
    Problem Solver:
  • 9 Answers
  • 21 Answers
1. First of all, you must open the computer case (with power off), and werify the power cable and data cable of hdd. please detach and put them right back.
2. then power on your pc
3. you MUST press F2 for setup utility in order for correct setings of your bios. the message "strike F1 to retry boot, F2 for setup utility" came from the computer bios, not from Windows XP CD.
4. verify if you followed the correct procedure of installing an new hdd as is described on page 66 of owner's manual from dell.
"Installing a Hard Drive
1 Unpack the replacement hard drive, and prepare it for installation.
2 Check the documentation for the drive to verify that it is configured for your computer.
3 Remove the hard drive bracket (see page 64).
4 Attach the hard drive to the hard drive bracket:
a Place the small bracket tabs into the drive-securing screw holes on one side of the drive.
b Gently swing the drive toward the bracket and align the three screw holes on the other side of the
drive with the screen holes on the bracket.
c Attach the hard drive bracket to the hard drive.
d Insert and tighten all three drive-securing screws.
5 Install the hard drive:
a Place the two bracket tabs into the drive slots inside the bracket for the additional hard drive.
b Swing the bracket forward so that it is flush with the bracket for the additional hard drive.
c Replace the bracket-securing screws.
6 Connect a power cable to the drive.
7 Connect the data cable to the drive and to the system board (see page 53).
8 Close the computer cover (see page 75).
NOTICE: To connect a network cable, first plug the cable into the network wall jack and then plug it into the
computer.
9 Connect your computer and devices to electrical outlets, and turn them on.
See the documentation that came with the drive for instructions on installing any software required for
drive operation.
10 If the drive you just installed is the primary drive, insert a bootable floppy disk into drive A.
11 Turn on the computer.
12 Enter system setup (see "System Setup" on page 80), and update the appropriate Drive option.
13 Exit system setup, and restart the computer.
14 Partition and logically format your drive before you proceed to the next step.
See the documentation for your operating system for instructions.
15 Test the hard drive by running the Dell Diagnostics (see page 36).
16 If the drive you just installed is the primary drive, install your operating system on the hard drive."
that's all
Posted on Sep 23, 2008
Well i have a Aspire 5735 and i want to get rid of vista and install xp
You may need to change the boot order so that it starts with the CD drive instead of the hard drive. It fairly simple to do, you must enter the BIOS by usually by pressing del or F2 repeatably during start-up, it may vary and the Acer key may be different. Then find something that says Boot, and follow the instructions to put the CD/DVD drive to the top of list or first. Then put your Windows XP disk in and save changes and exit. After restart you should boot from CD and follow the XP installation instructions. You may want to re-enter the BIOS after XP is installed and switch the boot order back to hard drive
FYI some computers have a force boot option in the BIOS that you can use to directly boot from the CD one time for OS install purpose.
Dec 18, 2012 | Acer Computers & Internet
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
May 16, 2010 | Compaq Presario CQ60-220US PC Laptop
Acer aspire 5610 new hard drive need to load xp operating software help!
hey... to install XP to the hard drive, u need to restart the PC with XP CD in the Drive... When the computer starts up you'll need to press F10 or F12 to bring up the boot menu (it depends upon ur motherboard type).. select boot from CD n follow the instructions....
Apr 02, 2010 | Microsoft Windows XP Media Center Edition...
I want to istall a new Hard drive, and I want to
Assuming you don't already have a second drive with an OS loaded then you will just need a boot disk or a Windows XP installation disc. Install the drive and then insert the CD. Power the PC on with the disk in the drive an you should get a message to boot from CD, just answer yes (note: the PC may boot automatically off the CD). If this doesn't work then you will probably have to go into the bios and change the boot order to make the CD as the first boot source. Entering the bios is different on each PC so, you will just have to find out the key sequence, usual buttons are ESC, F2, or CTRL+DEL.
Nov 17, 2009 | HP Pavilion Elite M9400F PC Desktop
I can boot up when i put in my new hard drive
New hard drives have to be formatted and an operating system installed to be able to boot up.
The operating system depends on what you want to put on there
As you are posting in the XP HOME section I would suggest you set your bios to boot from CD
Place the XP HOME CD in the drive and boot up
It will say press any key to boot from CD DO SO !
Follow the on screen instructions until setup is complete and then start to install the drivers you need and activate XP
Sep 21, 2009 | Microsoft Windows XP Home Edition
Installing 500 GB EIDE HD in a SONY PCV-RX560
what are the jumper setting on the hard drive. make sure the old one is the master and the new one the slave.
Jun 13, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
Xp pro set up
copy ntldr file from i386 folder and paste in C:\
steps
  1. Use the Windows Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\ If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.ini A list similar to the following list appears:
Feb 22, 2009 | Microsoft Windows 98 for PC
Reformatting
just make sure in bios that your first boot device is cd rom,then install the cd and follow the instruction
May 08, 2008 | Dell Dimension 3000 PC Desktop
Bought a new hard drive today, eide 320GB, and had the geek squad install it at Best Buy. I was led to believe that I could put my Windows XP in the CD Rom and install it but it is not working. Boot...
if you are wanting to install XP onto your new drive from your original XP CD, then you have to make sure you are booting from your CD drive first. If you have not partitioned the drive yet, then it will start installing on it's own. If you have partitioned and formatted already then be sure to press a key when propted to boot from CD. Make sure you are booting from your CD drive first is the most important part. Hope this solves your problem.
Apr 19, 2008 | Computers & Internet
Need to install OEM Windows 98
ok you need to reboot your computer from the CD rom with xp disk in it.
start your computer hold down the f12 key, a small menu will come up , pick cd/dvd/cd-rw drive with your arrow keys ,
select enter , follow xp directions on how install operating system on the monitor.
Jan 15, 2008 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
Dell Dimension 3000 PC Desktop Logo
1,014 people viewed this question
Alun Cox
