Question about SanDisk Sansa e260 MP3 Player
.. screen ? black and white marks ?
It was fine the day before, and today, when i took it out of my bag, the screen is all white, except for a leaf-like mark in the bottom right corner. when i plug it in to the computer, it shows up like it normally would when the screen isn't messed up. the blue scroller thing still works and all the songs are still there. i've tried resetting it a couple times, but when i turned it back on, the same black and white screen shows up. why did this happen ? is there a way to fix it ? thanku (:
  • eiubeergirl Sep 22, 2008
    I have the same problem. I had accidently rolled my chair over it and the screen turned white with the black glob in the top right had corner. I don't think it can be fixed, because I know when the pixels get popped on a cell phone, it can't be fixed.
  • knitone Sep 24, 2008
    I b
  • 281 Answers
You need to change the battery
Posted on Oct 13, 2008
I dropped my phone in my bag for like 3 seconds & took it back out and there was some water on the bottom of the bag and it got a little bit of water on the phone . Now my touch screen wont work . When...
if you fix it by yourself..need to make the phone or board dry... gentle open the screw (w/care) the use hair blower all over with it.not only the touch screen... otherwise,need to replace touch screen or bring it to the nearest service center
May 29, 2011 | Cell Phones
I have Canon iR2016N machine in my office. Since the day before yesterday, it is giving SYstem Error E007. For this error, I took out Film Assembly to check the status of Film and whole assembly. I found...
E007 means that the fixing film sensor cant detect rotation of fixing film.
In most cases because the white mark on the left end of foil is damaged.But also when the fixing film does not rotate well due to "baked" fixing film grease. I would suggest you to remove fixing film from heather, clean the grease leftovers and apply new fixing film grease.
Also it can happen if the white rotation mark is dirty or if the rotation sensor is faulty.
Hope that helps
Feb 08, 2011 | Canon iR 2016i Black and White Copier
Hi, I have a camera, a Sanyo VPC-T1060 and it's having some problems. It turns on, flashes, takes photos apparently, but the LCD screen won't work. It turns white when I turn it on and when I take a photo...
Try to remove the memory card if used, and blowing out the connectors in the camera cavity with compressed air (to remove dust if any).
Make sure the contacts are clean. If necessary try another memory card.
I'm not sure about the lcd screen, except it may require service from
Aug 14, 2010 | Sanyo VPC-T1060 Digital Camera
Screen is black and white but plays fine
try a different tv set as it could be setting on you tv which is causing the black and white.
Oct 30, 2009 | Microsoft Xbox 360 Console
SONY DSC-T70 blank screen! touch screen camera T^T!
The same thing happened to my Sony DSC-T70 today after I dropped it. White screen with green vertical lines. Need help!
May 11, 2009 | Sony DSC-T70 Digital Camera
Maybe rzr v3m; black screen after dropping phonein water
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Apr 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Water Damage - Nokia N95
Can you open your n95 by yourself? if yes, detached the LCD then cleand its LCD connector by alighter fluid using a small brush..thank you..
Feb 05, 2009 | Nokia N95 Cellular Phone
Broken nikon coolpix L18 camera screen
I just spent a whopping 10 minutes removing 6 small screws. I had to wrestle it a littl to seperate the case, but once open the screen lifts out. Attached to a ribbon cord. Carefully unlock the cord, replace LCD, reassemble. I'm seeing about $55 bucks for this screen. You can do it yourself.....Good luck.
Jul 07, 2008 | Samsung Digimax S500 Digital Camera
Black screen
take the phone and have the flexcable replaced
Jun 06, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Black screen
whats up with blackscreen?
Oct 08, 2007 | Fuji FinePix F460 Digital Camera
SanDisk Sansa e260 MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
