I have a 4x4 evo 2 game and it is not installing. It starts to set up the installshield wizard, gets to 99% and then quits. we are running it on a computer with windows vista software. any thoughts?
3 Suggested Answers
Boba
  • 64 Answers
SOURCE: DRIVERS WILL NOT INSTALL W2K SYSTEM.
Try the following driver: http://sdkbase.smartdisk.com/display/2/index.asp?c=cpc=e72ylkXWR8u0YnrbMviY&cpc=&cid=1&r=0.6935694
Posted on Feb 02, 2006
  • 53 Answers
SOURCE: unable to install on windows vista-starts installshield wizard but never gets past 99%
try this...make sure all pc protections are disabled, firewall, and any antiviruses and spyware of all kinds...usually solves these cases for me....hope it helps.....shia
Posted on May 03, 2009
  • 269 Answers
SOURCE: Error 1607 unable to install InstallShield
how you fix it
Reinstall the InstallScript engine loadTOCNode(2, 'resolution'); To reinstall the InstallScript engine from InstallShield Developer, follow these steps:
  1. Download the ISScript7.zip file. To do this, visit the following InstallShield Web site: http://consumer.installshield.com/kb.asp?id=Q108322 (http://consumer.installshield.com/kb.asp?id=Q108322)
  2. Extract the ISScript7.zip file.
  3. Double-click the ISScript.msi file.
Running Setup from a virtual drive loadTOCNode(2, 'resolution'); If you are running the Setup program from a virtual drive created by using the SUBST command, you can delete the virtual drive and instead run the Setup program from the physical hard disk. To delete the virtual drive, click Start, click Run, type subst drive_letter: /d, and then click OK.
good luck
Mel
Posted on Jun 06, 2010
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
When I play 4x4 evo 2 on my xbox 360 it will not save or load
Rob B is totally wrong, it has nothing to do with your 360 over heating or going to have the Red Ring Of Death. I am having the same problem too. Some of the old xbox games are compatible with 360 but some have bugs that do in some case render them unable to play to optimal performance. Try switching your display settings, I have one game that won't play at all unless my display is at 480p
Feb 19, 2010 | GODGAMES 4x4 Evo 2 for Xbox
I am having no luck installing Spongebob typing on Windows XP
Seems i had this problem with another spongebob game.
Try downloading and installing installsheild.
here is a link to it.http://software.informer.com/getfree-installshield-wizard-vista/
Uninstall game files before you install install sheild
You may also want to run windows update for a more updated version of xp
Thanks
Jan 22, 2010 | Encore SpongeBob SquarePants Typing...
Pc Game Error
Hi! I'm trying to install My Horse and Me the PC game, the installation goes through everything normal and but when I press Finish it gives me this error message
Unhandled Exception
Error Number:0x80040702
Description:Failed to load DLL:GameuxInstallHelper
When I press OK the installation window where you press Finish pops back up and it says
InstallShield Wizard Complete
The wizard was interrupted before MyHorseAndMe could be completely installed.
The system has not been modified.To install this program at a later time,run the installation again.
Click Finish to exit the wizard.
So I press Finish and then if I try to go and find it its not there its been uninstalled. And I have tried installing it several times with no luck .
So if you could please help me that would be wonderful because I really want to play my game.
Thank You!
Nov 14, 2009 | Atari Video Game Consoles & Games
My BB pearl 8110 keeps rebooting on its own.
  1. Right-click the Windows Taskbar.
  2. Select Task Manager.
  3. Select windows installer from the Applications tab.
  4. Click End Task.
  5. Perform a clean uninstall of the BlackBerry Desktop Software.
  6. Reboot the computer.
  7. Reinstall the BlackBerry Desktop Software.
Follow the trouble shooting steps for uninstall of the BlackBerry Desktop Software.
Task 1: Uninstall BlackBerry Desktop Software
For Windows 98/ME/2000/XP
  1. Close BlackBerry® Desktop Manager, if it is running.
  2. Open the Control Panel and double-click Add or Remove Programs.
  3. Select BlackBerry Desktop Software and click Change/Remove.
  4. On the InstallShield® Wizard window, select the Remove option and click Next.
  5. On the Uninstall Options window, select the check box labeled Remove all user settings for BlackBerry Desktop Software.
  6. On the Confirm Uninstall window, click OK.
  7. On the InstallShield Wizard window, click Finish.
Task 2: Uninstall BlackBerry Desktop Software
For Windows Vista®
  1. Close BlackBerry Desktop Manager, if it is running.
  2. Open the Control Panel and click Programs and Features.
  3. Select Uninstall a program.
  4. Select BlackBerry Desktop Software and click Change/Remove.
  5. On the InstallShield Wizard window, select the Remove option and click Next.
  6. On the Uninstall Options window, select the check box labeled Remove all user settings for BlackBerry Desktop Software.
  7. On the Confirm Uninstall window, click OK.
  8. On the InstallShield Wizard window, click Finish.
Oct 26, 2009 | RIM BlackBerry Pearl 8100
Unable to install on windows vista-starts installshield wizard but never gets past 99%
May 02, 2009 | Computers & Internet
Is the Driver Detective - InstallShield Wizard is what the IC150C
1st You download Webcam Driver.
InstallShield Wizard is what the IC150CAfter this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 21, 2009 | Micro Innovations IC150C Webcam
Help me
you cannot download sims games because you need the sims disks to play the game nad when you install the game and expansions the install wizard will tell you wich disk you need to play the game.
Aug 16, 2008 | EA - Electronic Arts Sims: Complete...
Jan 11, 2006 | Zio Corporation CameraMate VideoSafe...
Desktop Software Will Not Load!
The problem that you are encountering right now is a windows problem. "idriver.exe" is related to the installshield application on your computer and installshield is used to install application on your computer, so if idriver is not working, installshield will not work also. I suggest try the windows update. It might fix the problem.
Sep 11, 2005 | Palm Tungsten E Handheld
Open Questions:
USA***1~877~778~89~69***Avira Antivirus Support Helpline Number? USA 1-877-778-89-69 Avira Antivirus Support Helpline number is straightforward to use. Avira Antivirus Support phone number is open twenty four hours daily and seven days per week.Avira Antivirus support Helpline Number's agent will assist you with remote help.Avira Antivirus Support Helpline Number 1-877-778-89-69 is one of the most promosing and helpfull number of any Antivirus issue's.We are open 24*7,ready to solve your problem with just a TollFree call:-1-877-778-89-69 .Our expert team finding your issues area and solve the problem in faster and easier way.We are Happy To Help You.We are Avira Antivirus SupportUSA.A single call will change your life.just dial:-1-877-778-89-69. For any question or help:-1877~778~89~69. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number.
Mar 24, 2017 | Avira Computers & Internet
Computers & Internet Logo
52 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
