Question about Mitsubishi SL1U Multimedia Projector
No image Just happened! Turned on proj. and laptop, but no picture . I tried doing the function button and F8 but no good. I tried rebooting, no go. When I picked it up, it seemed hotter on the bottom than I recall. It's been a few weeks. Any idea?
  • lindatrains Sep 19, 2008
    Oh my, of course I checked the connection and the user manual. This is why I'm posting this question to you! Any one else have a solution?
    The warning light did not go on , so if there is still a light projecting, would the bulb be bad? I had already checked the filter and it was clean, as I clean it regularly. Any ideas?
    Master:
  • 441 Answers
    Sergeant:
  • 399 Answers
Check the fan if its properly running.its the faulty cable replace the wire.
thanks.
Posted on Sep 19, 2008
  • 4,234 Answers
First lets determine whether the projector is capable of producing a picture.
1) If you hit the menu button, do you see a menu on the screen? If not, then the problem is inside the projector.
2) You state that you see light. That would indicate that the lamp has fired and should be good.
3) Is there a shutter button? Some projectors allow you to do a quick "fade to black" by closing a shutter. Check for this.
4) If you do see a menu, run thru each of the input possibilities. If you have selected the wrong input mode, there will be no picture.
Please update this with what you find and we'll continue from there.
Thanks,
Dan
  • 6,487 Answers
Check first if the fan is working fine , because this can be a overheating problem and it will result to this problem of your proj.
    Sergeant:
    Champion:
  • 317 Answers
Check to see if your cable has any bent or broken pins, happened to me once, all I had to do is carefully unbend the pin with pliers (ultimately, use another cable). Also, check if it hasn't burnt out already, too much heat can ruin it.
    Master:
  • 505 Answers
Is the fans working properly cause if it overhead from not ventilation it can cause something similar to this. also projector lamps only last any from 700 hours to 1000 hours depending in the brand.
    Master:
  • 763 Answers
Did you try to look on the manual of you projector? see also the connection of your laptop to your projection it maybe loose the cable on it. hope that helps!
CHARCOIS
When I get to loading please wait the system goes no futher
try safe my by hitting the function F8 while it is booting up and loading windows. then choose safe mode. if you can get into it shut it down and reboot in normal mode. If no good repeat steps except once you are in safe mode roll back te reg before the date that it happen. Good luck.
Oct 23, 2014 | Computers & Internet
How do I reboot my windows 7 laptop
try this press power button with F8 engaged should go to safe mode
report back on this first solution with results
Jun 03, 2012 | Computers & Internet
Hi, i have a dell inspiron 6400 and since yesterday when i turned it off it re-started itself on and enter directly in to the media direct express automatically. i´ve been starting it and pushing the...
turn off, as it starts to reboot tap f8 key continually and choose safe mode. from safe mode do a system restore to last restore point before problem began.
good luck
Oct 21, 2010 | Dell Inspiron 6400 Notebook
Monitor remains black when computer is turned on (images there but black). happened before, hit Function/F8 (crt/lcd). would turn back on. now it doesn't. argh.
If you barely see images on screen, try to use function key and Up arrow key together to increase the brightness.
If not working, then the backlight bulb of LCD is failed and need to replace.
CompQ
May 11, 2010 | Dell Inspiron 1100 Notebook
I have a Dell D600. It starts up to boot page and after 3-5 seconds the picture disappears but the laptop is still running. The indicator light near the power button with a 9 on it stays lit.
I have a similar problem currently. Boot and try pressing Fn+Up arrow repeatedly to raise brightness. Then flick the little button right above your volume control that tells the laptop youve closed it. If you see the screen flicker on/off then its the button. Otherwise reboot and try shining a light at the screen from different angles and see if you can see dark images. If you can see windows boot up but dark, then it is almost certainly your LCDs backlight. If you can't see dark images, next try using the VGA output plug at the back of your laptop to connect to a different monitor. Within less than 1 minute you should see the image on the external screen. If not, try pressing Fn+F8 a few times to toggle the output. If still no picture on the external screen your video card might be fried. If you do get a picture on the external with or without seeing dark images on the laptop, then it is a problem with either the LCD screen, it's inverter, or the screens flex cable. Check Dell support for your systems original parts list HERE. You will need your laptops Service Tag number, which is on a sticker on the bottom of your laptop.
Hope this helps, Good luck.
Mar 06, 2010 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Hello, i have a latitude D 600 and tried to turn it on today, after the boot screen has shown and Microsoft started to load, the image on the screen started to blink and image was moving from bottom to top...
I think as per your question this seems to display resolution problem happens some time with games.
For this follow these steps
1. Switch on the Laptop
2. When you get screen before use F8 function keys for few seconds until you got a list of options.
3. Then select "Safe Mode"
4. After entering into safe mode then reset the default display settings to 800by600 and apply.
5. Restart the system.
Hope this information is useful
Thanks & Regards
M. NANDA KISHORE REDDY.
Oct 22, 2009 | Dell Latitude D600 Notebook
Laptop crash after inserting blank disk
do not worry at all. take out the cd and reboot in safe mode by pressing F8 at bootup. Then you can restore your laptop to an earlier date from Start->All progs->Accessories->System->restore. reboot normal this time.
Oct 04, 2009 | HP Computers & Internet
Regarding sound problems in my laptop
Try Fn/F8 (function/F8). It turns the sound on/off.
If that doesn't work, try rebooting 3 times.
Lately, Windows Service Pack updates have been breaking compatibly with Compaq sound drivers.
It happened twice to me with Vista. It takes a couple of reboots before Windows gets the drivers downloaded?/installed properly.
Nov 10, 2008 | Compaq Presario Notebook
5720Z acer aspire notebook has power light on and another flickering LED but no picture
Hey Rissa
Press the power button until it shutdown and then restart the machine. Press F8 contiuously till it prompt to some option. Choose restore directory......
good luck
zinja
Sep 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
Mitsubishi SL1U Multimedia Projector Logo
126 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
