Question about LG DLE2514 Electric Dryer
LG 2514W Rear Seal
Hi Rick: Follow-up questions:
1. Where can I get a rear seal for this unit?
2. I still cannot tell whether I would take the top off and the front off, then remove the drum from the front by bringing it towards me (in front of the unit) or do I remove the top, then the back panel? The service manual doesn't make this clear to me at all.
3. What type of adhesive would be best to use? Is it really just glued on?
  • Keith Milne Sep 19, 2008
    Thank you, Rick. I'll let you know about the assistance from the repair man. I did say Western MA.
  • 706 Answers
I've used a company called MCMINONE online to order most components for LG products. Try them first.. If that fails to reap benefits.. I would call appliance repair shops in your area or search online for parts for LG products.. ( there are numerous hits if you do that) and get your parts that way.
You will need to remove the top and front to pull the drum out and that is done typically by removing three screws on the back of the cover.. to allow it to slide toward the back of the unit then you should be able to lift it off. You'll need to unscrew the filter housing and with the top cover removed you should be able to remove a few sheet metal screws to detach the front panel.. You'll also have to disconnect the door switch... and the drum belt.. ( here is where you may want a digital picture to use as reference when reinstalling it.. )
As for gasket cement, you can get some in a small container at an automotive parts store of the parts house you find to get your gasket should be able to provide that too..
I am in my day job now ( lunch break) and can assist you better from home later on if you need any additional information.. feel free to ask.. ( If I recall correctly, did you say you lived in western mass?) If thats true, I may know arepair man that would be willing to assist you.. but I would have to ask first.. Please advise on that one.. TTYL
Posted on Sep 19, 2008
I have 2 numbers on the 350 block....15R518026 and 10701CMJ like to know what year. have a rear main seal leaking...is it 1 or 2 piece seal.
If it is a one piece seal there will be bolt holes at the rear of the crank for the seal adapter.
Jul 06, 2017 | Cars & Trucks
How to replace rear axel seal on a 2000 ford mustang
FOLLOW INSTRUCTION IMAGE
1-SPARE PARTS NUMBERS.
2- CON.....
3-NOTICE.
4- REMOVAL. Use recommended tools.
5- INSTALLATION.
Sep 12, 2014 | 2000 Ford Mustang
Is it worth it to fix a 99 F250 SD that has a rear main seal blown on the engine?
Until the engine is sealed you will not know how much oil is burned. Price the parts. Difference too in whether its a 4x4 or easy access 2 wheel drive.
Check rear seal type to see if it can be changed by pulling trans and flywheel. If stick shift, probably good idea to replace clutch disc to verify not oil soaked. If automatic, oil is no consequence.
Kind of matters how much is wrong. With trans out, some rear engine seals can be replaced without removing oil pan. But if bearings are bad, on 2 wheel drive you may be able to squeeze off oil pan and check bottom of bearings.
You can do poor man's bearing job with plastic-gage. Rod bearings can probable be switched 100%. Main bearings lower cap can be serviced with upper 1/2 left in place. Not ideal, but can save from pulling motor.
Value depends on whether your Labor is free. You have a 14 Year ol truck. Depends on what you already replaced to maintain it or what else it will need. You could need rings after working on the bottom end even with a poor man's bearing job. Plastic Gage can tell you the size you need for each bearing. Then keep track and only buy individual sizes.
If you could find a wrecked truck with a good engine, places like carparts.com have a good multilist. Rule of thumb is different for each person. I would look hard at spending 1/2 of what truck is worth to fix it, knowing other things are wrong.
Mar 19, 2013 | Ford F-250 Cars & Trucks
How to replace rear main oil seal on vx commodore 5.7 auto
To replace the rear main oil seal I would recommend changing the whole rear main plate with gasket seal already done.
1.disconnect battery
2.raise vehicle on hoist
3.remove exhaust
4.remove tail shaft
5.remove starter motor
6.disconnect and remove transmission
7.remove ring gear
8.you will now see rear main assembly.
9.undo bolts holding rear main plate on
10. remove plate and clean surface area,follow these steps in reverse to refit...
Oct 12, 2012 | Holden VT Cars & Trucks
How to replace my 1994 lincoln towncar rear axel seal
you need to pull the cover off the rear diff. remove the rear brake drums or rotors, remove the bolt that holds the pin in the rear end, remove the pin, remoce the c clips, pull the axles out. remove the seal. you can do this by using one ofthe axles to pry the seal out. install the new seal and reassemble. use rtv sealant to reseal rear diff and fill with about 3 - 3 1/2 qts gear lube-may take synthetic
May 23, 2009 | 1994 Lincoln Town Car
How do i fit the door seal
hi the door seal is held in place by two large clips wjth screw tightening best access is to remove the top row screws on rear panel these also hold the top panel then lift top panel at rear and pull top backwards and clear of front facia then lift top off ok ? now you have access to the door seals clips which secure seal to front panel and the outer drum loosen screws fully this releases clips enough to gently remove seal clean surfaces of seal to drum and front panel then fit new seal as previouse one resecure clips then re assemble covers hope this helps and clear enough ?
Mar 09, 2009 | Hotpoint BWM12 Front Load Washer
LG 2514W Rear Seal
Hi kc,
You are on the right track, the dryer has many screws and sections to pull off including the top and front. I use a plastic scraper from Ace Hardware to remove old felt to prevent scraping enamel on drum. Note how the belt loops on the tensioner to the motor pulley.
Sep 19, 2008 | LG DLE2514 Electric Dryer
Main seal
First is it a front seal ,or rear main seal,(front seal,being were you see the pulleys and fan belts,,you have to look at the bottom pulley,follow the shaft to the motor,where the shaft goes into the motor is the front seal,the pulley and everthing behind it has to come out then you pull out the seal,auto zone actually has free tool rental that you can pull the seal,and a tool to put it back in,if a rear main seal its where the shaft from the transmission meets the back of the motor,youll have to pull the trannsmission back,check where you see the oil leek from,the front seal you can do if mechanically inclined,but if its the rear you should take to a mechanic,if this helps please give me a fix ya vote
Jul 14, 2008 | 1997 Chevrolet Malibu
LG DLE2514 Electric Dryer Logo
96 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
