Question about Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens
Aperature ring adjusting the ring doesnt adjusting the aperature
    Sergeant:
    Champion:
  • 435 Answers
Hi, Is the aperture in max or min ?
Remove the lens. Try pushing the stop down lever and look through the lens if the aperture changes.
Look at this pic if you wonder what stop down lever means. http://www.mir.com.my/rb/photography/hardwares/nikonfmount/20AI-S2_8rearconv.JPG
cheers,
Posted on Sep 21, 2008
I've been reading all the messages and Im getting the same FEE code. It works while manualy putting it on the F22 aperature setting. But I was wondering why I can no longer manualy control my aperature...
Leave the aperture ring at f/22. You can then control the aperture from the camera body, the same way you would with a lens without an aperture ring.
Jan 05, 2011 | Nikon N65 35mm SLR Camera
It keeps flashing "FEE" in the information screen. What am I doing wrong?
It is indicatin that there is a problem with the aperature coupling to the lens.
If the lens has an aperature control ring twist it round to either the samllest f-stop ( largest number ! ) or to the 'A' setting is it has one.
If it is a later lens that does not have a ring, try twisting the lens off and on a few times to clean the contacts, or wipe the contacts on the back of the lens and body with a dry rag.
There should also be a switch arm to the left of the lens mount, at about the 8 o'clock position - this should be pushed by the lens in the conditions above - make sure it is not jammed.
Jun 15, 2010 | Nikon N65 35mm SLR Camera
FEE keeps flashing with aperture ring nikor lenses
Your aperture lenses should be set to the biggest f-stop (smallest aperture)
Jun 07, 2010 | Nikon D70s Digital Camera
My aperature setting flashes E.E when I put my lens on my camera.
make sure the aperture ring on the lens is set to it's HIGHEST number (f22 or f32) it might be a different color than the others and flip the little switch that locks it into place.
Aug 27, 2009 | Sigma 70-300mm f/4-5.6 DG APO Macro Lens
Nikon D50 reads [-E-] in window not viewfinder and won't shoot.
This is the error code for having a lens with manual or auto aperature adjustment in manual mode with the camera in anything other than "M". You need to put the lens in the max aperature (usually it's red) and then move the small red switch to the red dot. I don't think anything else will give you this error.
Aug 25, 2009 | Nikon D50 Digital Camera
Just bought a new Nikkor 70-200 AF-S VR lens. I CANNOT remove the rear lens cap, nor are there directions for removal in the instruction manual. Is there a secret ?!? Many thanks! (I am feeling...
Did you try twisting the aperature ring to release the lens cap? You can't just pull it off, as the body cap locks on by twisting the aperature ring.
Dec 17, 2008 | Nikon Cameras
Nikon NEWBIE
put simply the ISO number is how sensitive the film is to light, the higher the number the more sensitive the film. The ISO on the camera sets the exposure system to give the proper exposure for that film (the f/n80 usually sets the ISO automaticly). Also the higher the ISO the more grainy the picture, I would recommend using ISO 200 film for the pictures you describe. I would set the camera to the P setting it is a good all-around setting.
Nov 18, 2008 | Nikon F80 35mm SLR Camera
Canon EOS 40D aperature issue
Check the operators manual - you need to 'activate' the aperture control.
Jul 15, 2008 | Canon EOS 40D Digital Camera
External Flash
The aperature error is due to the fact that the lens in not a constant aperature design. The settings on the LCD are assuming you are at full wide angle setting. As this lens moves towards telephoto, the aperature changes about 2/3 of an f-stop due to the mechanical movement of the lens elements. So a manual setting of f4.0 at full telephoto will be more llike f5.0 in reality. It is too bad Epson could not make the mechanical aperature adjust to compensate, but every nice feature costs something. I have not had any issue with the shutter speed changing. One guess is that the camera has shutter speed/aperature combinations that it can't achieve due to mechanical limitations, so it chooses the available combination. Another is that it wasn't in manual mode, but rather aperature priority mode and the final adjustments changed the speed.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Aperture priority only in manual mode?
Yes. You pick the apature (the 3000 keeps it aorund the setting you pick) and then it automaticly adjusts the speed for you.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens Logo
146 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
