Question about Haier Microwave Ovens
Haier microwave refuses to power up; I made sure the outlet has power and also opened it up to check the fuse. I replaced the fuse and still no power. Is the thing just "dead dead dead"?
  • Haier Master
  • 9,086 Answers
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
To my knowledge, service information may not be available for Haier microwaves, but they're similar to most others. Here's a primer.
You can contact Haier customer service here.
You can find out where to order Haier parts here.
Posted on Sep 26, 2008
Where is the fuse on Panasonic NN-S252
You may have to remove the cover on the microwave to find a fuse. It may not be either in a fuse holder or soldered into a the circuit board. be sure it is not plug up when you check.
if you find it be sure and replace with the fuse with same current rating.
Aug 01, 2014 | Panasonic NN-S252WF Microwave Oven
I turned on microwave. lost all power after a few seconds. outlet has power
First, check to make sure you have 120 V at the outlet it's plugged into. If you do, then the most likely cause would be that the main fuse has blown. It is inside the case, usually near where the power cord enters the cabinet. If it is blown, visually inspect it to make sure it hasn't been getting hot - melted solder near the ends is the usual tip-off. If it has been heating up, the fuse holder may have to be replaced as well as the fuse.
May 10, 2014 | Samsung SMH1816B Microwave Oven
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
GE Microwave Spacemaker2. The toouch screen does not respond
could use a little more detail.
when u have no display screen the solutions are. possible causes * A fuse in your home may be blown or the circuit breaker tripped. A. Replace fuse or reset circuit breaker
* Power surge. A. Unplug the microwave oven, then plug it back in.
* Plug not fully inserted into wall outlet A. Make sure the 3-prong plug on the oven is fully inserted into wall outlet.
* Door not securely closed. A. Open the door and close securely.
Jan 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do I replace the internal fuse on my Over the Range GE microwave? I opened the microwave door and and there was a quick spark after which the microwave went dead with no power. I have checked the...
I would say the lamp popped and took the fuse, so you will need to replace the lamp also.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARRAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 05, 2011 | GE Microwave Ovens
No power and I replaced fuses in microwave.
Have you checked to make sure that you have power coming in to the unit? Check the fuse to the outlet that the unit is connected to before we go any further.
Nov 26, 2010 | Samsung SMH7178STD Microwave Oven
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
Just quit. No power, no display....nothing
there are several possible causes, check voltage at outlet
check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
Sep 10, 2009 | Samsung MS1040BB Microwave Oven
Microwave jsut went dead. No power, and there is power at the outlet.
check the fuse inside, watch out with those can capacitors as they can give you a nasty shock. For your protection unplug the microwave and wait 24 hours to let the capacitors discharge, then open and find fuse which is usually near the power supply, check fuse, if dead replace it.
Josh, South Carolina
May 03, 2008 | Whirlpool Microwave Ovens
Microwave oven
Check the wall AC outlet by using a meter or another electrical appliance such as a table lamp. If no power there replace the fuse or reset the circuit breaker.
Does your microwave light up when you open the door?
If not, it could be a bad power cord, on/off switch AC cord or fuse.
Check these first.
If you cannot solve the problem, you'll probably need service.
Hope this helped.
Mar 25, 2008 | Panasonic NN-P794SF Microwave Oven
Microwave Ovens Logo
556 people viewed this question
Top Haier Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Haier Microwave Oven Expert? Answer questions, earn points and help others
