Question about Sony (DDU1613) (ddu1613black) Internal DVD Drive
Sony dvd/cd drive m/n. AD-7190S
Installed in tower but windows xp does not find it has power is conected to sata on mother board
Sir my dvd writer dvd write from nero but no dvd write from magiciso but cd write from magiciso software
Posted on Nov 28, 2008
I have a ASROCK G31 945 intel MOther board , When i purchased i fiited with IDE CD/DVD Drive . INow is it possible to connect the SATA CD/DVD drive to my mother board. i have SATA connector on my MB ....
You need is an open slot for the drive, an available SATA slot / cord, and a SATA power. It may require you to go into BIOS, and in some cases a driver for the new drive. Don't forget the SATA drivers if you have XP.
GL
Oct 08, 2012 | Intel ASRock G31M-S M/board - Intel...
How do you install an lg gh24ls70 dvd rewriter into a compaq presario computer runnining windows xp that is 8 years old
If it's a sata connection on the drive you may not have any sata sockets on the motherboard. You will need something like an IDE to Sata adapter like this one: Adapter.
Feb 18, 2012 | LG Computers & Internet
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
Old hard drive died so now have a western digital wd5000aakx. have pins 5&6 jumpered but cannot instal windows xp as no drive is recognised even after loading the sata drivers that camw with the...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 09, 2011 | Computers & Internet
Mon lecteur est en panne je veux le changer
You can change the dvd rom by opening the computer case and taking out the sata cable and power cable.
you can replace it with any SATA DVD+/-RW SATA Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
Windows XP, Vista and 7 will automatically install the new DVD drive for you.
Vous pouvez modifier le DVD-ROM en ouvrant le boîtier de l'ordinateur et en tenant le câble SATA et câble d'alimentation.
vous pouvez la remplacer par n'importe quel DVD SATA + /-RW SATA Drive
Windows XP, Vista et 7 installera automatiquement le nouveau lecteur DVD pour vous
Mar 01, 2011 | Sony Optiarc AD7240S DVD?±RW (?±R DL) ...
I installed the DG43NB mother board and it is not recognizing my hard drive. I am running windows XP and I have installed the raid driver and I'm still not able to run it
Boot her up with a xp cd in the cd/dvd drive. She will take boot sector from there. Problem is that you mounted a SATA drive on an old IDE motherboard and used an additional PCI interface card that misfires
too fast or to slow to get xp's boot sector. Had such a case under my hands few months ago. This was the solution there.
Copied xp to a separate DVD and uses this to boot system, pc will only use boot sector from this and then use installed sata drive. Once fired up you can tempoerarily remove that CD/DVD and use for tasks.
Your problem lies in an older BIOS or older component. Maybe there is a later version.
BIOS flashing is tricky. Be sure to have backup before flashing. No experience leave it.
May 26, 2010 | Intel DG43NB Motherboard
Need to upgrade Sony Architect to be compatible with Windows Vist
http://www.sonycreativesoftware.com/download/updates/cdarchitectfamily if you are using 5.0 you will need to upgrade from the web site above, to 5.2 then do the 5.2 update as this is the Vista patch,
Apr 03, 2009 | Sony CD Architect 5 (sf2cdr5000) for PC
Sata problem
WHEN BOOTING TO LOAD WINDOWS XP START AFRESH BY FORMATING YOUR HDD FIRST AND WHEN U DONE BOOT YOUR SYSTEM UP FROM YOUR CD ROM THE DRIVERS WILL GET DETECTED AUTOMATIC AND THAN START YOUR INSTALLION.
Feb 06, 2009 | PC Chips M955G Motherboard
Sony (DDU1613) (ddu1613black) Internal DVD Drive Logo
112 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
