Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Sanning document MF6530 is connected to Windows 2000, service pack 4 PC with a USB cable of 20 feet. Installed Canon MF Toolbox 4.9. When actuating the start button the computer locks up. One document was previously scanned successfully, but am unable to duplicate a successive scan. Suggestions would be greatly appreciated. Marv Sachse
  • Anonymous Oct 23, 2008
    Same story here. It appears to be the long USB cable I'm using, not sure, though. It scans the first page, then stops halfway through the second. Recovery requires a Windows restart.
(I'm the guest above, logging in this time)
Posted on Oct 23, 2008
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
Canon imageclass mf 6530 blank pages change toners still blank what is the cause of this problem
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
Jul 19, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
How to get Canon MF toolbox to work with Win7 64bit.
I got mine to work. Just set the compatibility mode for the .exe file to Windows XP (Service Pack 2).
Jun 24, 2010 | Canon imageCLASS MF3240 All-In-One Laser...
Can't get usb to work. Has windows 2000 installed.
USB 2.0 is supported under Win2000 after Service Pack 4. Update your system (via Windows Update) to the current Service Pack and security patch level.
Dec 14, 2009 | Compaq Armada E500 Notebook
Canon mf4350d WONT scan out of the box
The software that comes with Canon MF4350 does not detect the absence of WIA service running. If printer is working and the correct driver is installed, the first thing to check is: 1. Check that the scanner does NOT appear under Control Panel -> Scanners and Cameras. 2. Navigate to Administrative tools -> Services (the same menu is available under My Computer -> Manage -> Services. 3. Check that service "Windows Image Acquisition (WIA)" is enabled and started. 4. If WIA service is not enabled, enable it. The scanner should appear under scanners menu (see 1.) and Canon MF4350 should work fine.
May 30, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
440 people viewed this question
old marine
old marine
