Fan Problem I just replaced the larger cooling fan and I did the same thing you did. If I remember correctly the original fan exhausted out the back in other words it drew hot air from around the the bulb and blew the hot air out the back of the set. The blue writing on the center of the fan blade is visible from the back side of the tv. I hope I put it back in. Would be great! to hear back. thanks Jonicat@aol.com posted 9/17/2008
  • 80 Answers
SOURCE: is there supposed to be a cooling fan for the lamp ??
Mitsubishi had a problem with the power board in a lot of the DLP sets. The fans would not turn on when they were supposed to, and the lamp would create too much heat. Call mistubishi support, have your model and serial numbers handy. Sometimes they will warranty this problem een after the 1yr warranty has expired.
Posted on May 21, 2009
  • 668 Answers
SOURCE: cooling fan no longer working on tv
Chances are good that it will work. The only catch is that one of the wires are monitored by the protect circuit. If the wiring is different it may not work. I would try it though. Nothing bad should happen. Make sure that if it does work that the fan is blowing in the correct direction.
Hope this helps,
Skyassoc
Posted on Jun 30, 2009
SOURCE: Four Blink Code on SONY KDS-60A2000 Rear Projection TV
I took a can of compressed air and blew air into the larger openings. A nice cloud of dust and several puffs of air later, the tv turned on.
Posted on Aug 05, 2009
SOURCE: Replacement Fan for KDS-R50XBR1
The fan P/N 883586011 is available from http://www.cwc-group.com/sff21c.html offer same day shipping just 15.00 and brand new
Posted on May 25, 2010
SOURCE: The fans on my Toshiba DLP frequently makes a loud
My tv just came on by itself and now just keeps going back and forth from off to on over and over
Posted on Jul 17, 2010
Which way does the rear fan go in a compaq computer tower
The proper installation of a CPU fan is often the subject of debate. Though there are conflicting theories as to which direction the CPU fan should face, there are methods to ascertain which CPU fan installation best suits your needs. The determining factors of your CPU fan installation direction include the manufacturer specifications, your case design and the specific design of your heat sink
Horizontal Installation
  • The installation of a CPU fan horizontally to the plane of the motherboard is the most common installation orientation there is. Your options when installing your CPU fan are to blow cool air onto the heat sink or to pull cool air through the heat sink from the motherboard. Horizontal installations show negligible advantages in either installation direction. The differences in temperature usually vary by only 1 or 2 degrees Celsius. The main point to consider when installing a horizontal CPU fan is the location of the rear exhaust fan on the case. If the rear exhaust fan on the case is parallel to the processor, it is advantageous to have the fan pull cool air from the motherboard and push it out above the heat sink. This is because the case fan will quickly draw that hot air away from the CPU and out of the case, allowing for quick cooling.
Vertical Installation
  • Vertical, or tower, heat sinks rise high enough off the motherboard to allow for a fan to be installed perpendicular to the plane of the motherboard. This allows for cooling to go from the front to the back of the case, as opposed to going from the bottom to the top. Optimal installations for vertical heat sinks are blowing toward either the back or the top of the case. If there is no exhaust fan in the top face of your computer's case, it is more effective to orient your fan on your vertical heat sink so that it blows toward the rear exhaust fan of the case. If there is an exhaust fan on the top face of your computer case, it is almost always more effective to mount your CPU fan so that it blows air up toward the top of your case. The reasoning behind this is that hot air rises and will more naturally flow off the top of your case. Also, top-mounted fans are usually larger and allow for faster airflow out of the case.
Manufacturer Recommendations
  • It is often the case with nonstock heat sinks that the manufacturer has designed the heat sink's fan to be mounted in a limited number of orientations. This is usually evidenced by limited mounting notches on the heat sink itself. Most aftermarket heat sinks use technologies such as heat pipes that have specific cooling needs to operate appropriately. Because of this, it is important that in any CPU fan installation you follow the manufacturer's installation instructions.
Performance chips of BMW
May 31, 2012 | Compaq Hp - 375376-001 - Dc7600 Tower...
What's your problem?tower fan is always running off and on
Your computer's Processor/CPU fan is set to run faster when it is hot and slower when it is cool. That is why it get's quiet and loud. A clean may reduce the noise, by removing the dust from the computer system the fans will be able to operate more efficiently and effectively meaning that they won't have to spin as fast.
Install fans in your chassis to provide your computer system with freash air, an exhaust fan is also an idea to push warm air out of the system. Generally the larger the fan the quieter it will be, as a large fan can spin at a slower rate to provide the same airflow of a smaller unit.
Remember that it is that fan over the CPU heatsink that is keeping your computer alive. Overtime they can wear, replacing the fan is an option.
Take care!
damnor01
Oct 06, 2011 | Dell Inspiron 531s Desktop Computer
I have a cooling pad and some of the blades have broken off is it possible to buy a new fan piece cooling stand f5l001
LOL it's just a single standard fan in there!  Replace the whole fan with one with similar specs (though of course you can get one with UV LEDs if you want.)  You're welcome to contact Belkin with the question you strangely placed here if you want Factory Original (as if such a thing was still preferred) parts.
Mar 11, 2010 | Belkin LAPTOP COOLING PLATFORM * WITH FAN...
I recently bought a Belkin multi purpose power adaptor to replace the original which had failed. This has melted and made the laptop unusable as it has melted all over the power outlet. PC World claim it...
If the POWER ADAPTOR failed and that is what melted then the ADAPTOR is probably at fault.
Nearly all GOOD power adaptors have thermal and/or current overload protection in some form.
If it was an AUTO-SENSE input voltage type then it failed in a BIG way.
If it was NOT auto-sense for input voltage then it may have been set for a lower voltage than was being supplied by your wall outlet.
If it was the latter then it was up to you to select the correct input voltage. For anything else I would be kicking some @ss.
Deal only with a full store manager and nobody else and document everything that is said.You didn't mention which country you are in but a lot of countries have consumer service departments and health and safety departments that can quite often take these sorts of thing up.
You may also find websites that list re-called or defective products.
If yours shows up on one of those sites print out the info and take that in with you.
Nov 15, 2009 | YS Tech Ball Bearing Fan Exhaust Fan
Engine overheats and cooling fan cuts off
try to replace the hoses, they may be collapsing, then replace the thermostat, and give it a radiator flush to clear any possible clogs in the lines, last thing i would say is to replace the fan
Jun 24, 2009 | 1995 Ford Escort
Exhaust fan running slow
sounds like the compressor is turning off cause of high pressure. check the coil that the exhaust hose connects to, if dirty clean it. if the fan is not blowing enough air threw the coil the unit will build up high side pressure and cut out, but will turn back on when pressure drops. if that dont help, maybe the fan motor is bad or needs taken apart and oiled.
May 31, 2009 | Maytag Portable Air Conditioner M6P09S2A
Older Superior Brand Kegerator Freezing
Sounds like the fan can be running backwards. I'm not sure of you exact model, but it has to match the air flow of the original unit. Do you remember? Some manufacturers use reversable motors and are some what easy to reverse.
Good luck and hope this helps.
May 08, 2009 | Danby DKC645BLS Compact Beverage Cooler
2003 Jag S-type engine cooling fan comes on and stays on
try replacing the fan stat, usually on the rad
Apr 25, 2009 | 2003 Jaguar S-Type
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
