Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Little light engine?
Did that fix your color problem? I am have the same thing happening and my TV is not under warranty!
  • Stylin Bobby Nov 29, 2008
    I have a lot of tiny dots, and in the periphery on the left. Is there anything I can do.
  • Anonymous Dec 26, 2008
    Same here, I believe this is related to the Blue Haze issue... (aka something expensive needs to be replaced).
  • Sony Master
  • 5,138 Answers
Replace Light Engine Call UED 1-800-648-6657
Posted on Dec 25, 2008
I have a vizio m421vt when it comes on just the vizio lights up , black screen, can't get sounds, no backlight, buttons on tv dont eork have to unplug from wall
Same thing happened to my Vizio TV. Fixed under warranty, replaced the motherboard. There are actually only 2 boards in the thing, easy to fix.
May 13, 2015 | Vizio Televison & Video
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
We have had the TV about a year without any problems. Today it suddenly started doing a weird thing where the color becomes a sort of pink overlay with all of the colors being neon-y and weird. It looks...
Ur tv still have a warrenty,it still under a year?Take ur tv warrenty repair quickly,this tv the Tuner signal board is the causes and the problems.That the board,where the inncomming broadcasting signal cable and externtal devices plug into it.This board is the second important thing to the tv,beside the tv LCD screen panel itself.
Dec 19, 2010 | Insignia IS-LCDTV32 32 in. Television
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
I have a modle #5p5040 philips projection tv that has a strange colored picture when it is turned on whats my promblem
My problem with my projection LCD was the light engine went bad, it manifested itself with a growing blue haze that eventually washed over the entire screen. Luckily I got it fixed under warranty because it was a $2500 fix. The light engine is buried in the TV and needs a professional to align it.
Oct 01, 2009 | Televison & Video
TV has little stars, and cuts off automatically
Go to the Samsung website, find your model under the search function, and click on one of the returned links. Once there, you should see a link that says "Featured Accessories". Click on that and you will go to the Authorized Samsung parts site, where you can find the EXACT cost of the parts needed. Hope this helps. Mine went out, and it was only $65.
Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
How do i fix or get rid of a green spot and a couple of purple spots on the tv screen?
Does your model end with a "5" as in PTnnLCX65? If so call the Panasonic call center to schedule service or find a servicer, they have a fix for colored spots on the 2005 MMDs ending with the number 5. The fix is being coverd under warranty.
Sep 14, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Little white dots on the screen
dirty lens, dirty mirrors, warped light guides, spider webs and mini-UFOs that fly across the inside can cause what you described.
but 6 months is pretty early for a cleaning but possible.
May 16, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arching
Same thing happened to me. I had to get it fixed. They said it was a "tube".
Now, my problem (7 months after getting it fixed) is that it suddenly seems a lot dimmer. I'm not 100% sure, and was wondering if there was some kind of diagnostic to run to find out for sure.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
No blue
Make sure your blue component cable is connected...this is the most common cause for complete loss of blue. If this does not fix it you are looking at having to get a new light engine for this tv. Sorry. Make sure it is not your source first...dvd..cable..etc
Feb 04, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
49 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
